Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Gas Furnace
Fan/Blower turns on but can't get the thermometer to trigger the switch to start the heat. Pilot light might be out. Can I fix this on my own without blowing the house up?
    Genius:
  • 1,554 Answers
There is no pilot light, its electronic start now.
like your stove should be.
you can trigger the furnace by shorting out the correct combo on the thermostat but not advised unless you know the right ones.
be sure the power is on the the transformer that provides power to the thermostat.
though that may be contained within the furnace now days.
just check your fuse box and call a tech.
Posted on Jan 26, 2008
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
3 amp fuse blows when call for gas after pilot runs for 30 seconds
check the blower motor for seized of burnt out. Fuses blow because of excess current draw and in this case if the fan is not starting everything will stop. The gas will be set so that if the fan is not running the gas will not be allowed to turn on
Nov 21, 2014 | GE Carrier Bryant Payne 1/3 Hp 115v Blower...
Model rgdg-100auer 100,000 btu with pilot light. i light the polit that is fine turn on gas that is ok runs for 1 minute then shut all gas off and i have to relight the pilot time after time but never...
If this happens each time the blower starts, you have a crack in the heat exchanger and need to replace furnace. If the blower is not starting, it could be a high limit opening up because of the heat being generated. By pass the high limit circuit to see if it stays on and the blower works. This is only a test procedure, do not continue to run system like this. If you have a manual fan switch, turn it on and then start the heater.
Feb 23, 2011 | Heating & Cooling
Burners not burning, pilot light is off. How do I start the pilot light?
There is no pilot on this unit. It is electronic ignition.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 29, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a carrier 58sx040. Sometimes after the pilot comes on the main flame will start then stop about every 3 seconds. This problem intermittent. There is always a noise coming from the gas inlet when...
Dirty flame rod, polish it with a scrub pad.
Mar 13, 2010 | Carrier Heating & Cooling
Having problems with Carrier 58RAV furnace. Goes through the motions, but gas never turns on. I think it is a problem with the LPGS. Please advise. Thanks
Dec 24, 2009 | Carrier Heating & Cooling
Carrier furnace, pilot does not light, fans run for a couple minutes and then flashes code 31
Nov 28, 2009 | Carrier 38CKC042 Air Conditioner
We have a Janitrol PGB 048125-1 unit and it is not blowing heat. the fan comes on when in fan only mode on thermostat but once we turn it to auto it goes off. we cannot get the unit to blow hot air. does...
If the unit is newer than 10 years I guess there will be no pilot light per sey. You will have to look at it to tell for sure. Here it is supposed to work. When there is a call for heat the thermostat will close and send a signal to the furnace to start the exhaust blower. When the blower gets up to speed, it closes a pressure switch that will send voltage to the gas valve and to the igniter. The igniter glows or sparks lighting the pilot. Once the pilot lights it sends a signal that all is well, then the gas valve opens up more and the burner(s) light. There is a sensor that tells the control board when the flame has stayed lit. Once that is done, after a period of time or as the heat exchanger gets to a specific temperature, it will turn on the room air blower and blow hot air. Once the thermostat has been satisfied, the furnace turns off. Now, get in front of the furnace and with the door panels off (you may need to tape down the door safety switch to make this work) watch the furnace go thru each step I described. Once you see where the problem is, you can start the proceed of repair. There may even be a flashing light indicating a problem. Find the wiring diagram on the furnace and look for a diagnostic chart and compare the number of blinks to this chart.
Oct 17, 2009 | Goodman Heating & Cooling
I have a Carrier 58SX060 Furnace with air. I turned the thermostat to heat and the exhaust comes on and runs and the pilot comes on but the burner never light s and the blower never comes on. If I turn the...
carrier gas furnaces will try to light three times then will usually go on a lockout for one hour you can bypass the lock out by resetting the power, turn furnace on, remove wires from gas valve, you will need a multi meter to check for voltage to valve, if control board sends a call to the gas valve the valve is bad, if voltage is never present during the lighting cycle your control board is bad
Sep 30, 2009 | Heating & Cooling
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
195 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
