Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi DLP WD-52525
Tv does not display video or audio only displays a checkered pattern on screen front panel buttons do not work only power button,remote control same.
  • Anonymous Apr 22, 2008
    I am having the same problem!!! I have let it "sit" and still have the checkered image...what is wrong?
  • 31 Answers
Your formatter board is bad. it can be repaired (sometimes) but they mostly just replace the part. hope that helps. need anything just ask
Posted on Apr 23, 2008
    President:
  • 4,402 Answers
First unplug and let it sit for a couple of hours and then try again.
Posted on Jan 28, 2008
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 52 in dlp tv screen needs cleaned
all you have to do is, take the 12 screws out from around the screen, from the back, there are also like 4 of them on the front, but usually , you can just lean the screen out far enough to use a swifer sweeper in there, and the dust isnt going to be on the back of the screen, it will be on the projecter, do the screen while the tv is on, then you will realy see the dust on the projecter
Jan 07, 2009 | Mitsubishi WD-52627 52" Television
Blue screen on WD-52525
wait the 4 days. any work done on it by a non authorized party could ruin your warranty
Dec 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi 52 projection tv bought at auction got home screen looks like bricks light and dark only static for sound power button is broke off used remote to turn on model wd-52525
Sorry to tell you this but you have a bad FMT board which is not available. When this board goes out it will display a checkerboard pattern on the screen, or it may not even turn on the timer light will just keep flashing.
Oct 06, 2008 | Televison & Video
Black and gray boxs show up on my screen
try to hook up signal diffrent instead of rf go video, or s video
i would try video if you have original remote see what happens
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with no video. sound ok. B&W squares pattern on pict.
hold the MENU and DEVICE buttons when turning on the TV and get error code
Oct 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
