Question about KitchenAid 24 in. KUDK02CR Built-in Dishwasher
Top rack remains dirty
Our dishwasher worked fine until a few days ago. The dishes on the bottom rack clean perfectly as usual but the top rack does not clean at all. Seems like it's getting only limited water flow and no detergent.
Spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Posted on Jan 27, 2008
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Have a whirlpool GU2400XTPT1 undercounter dishwasher for the past 5 years. Has worked perfectly until a few weeks ago the glasses and such on the top rack haven't been coming completely clean. Everything...
have you change you dish soap -to a phosphours free agent there has been rumor that these new cleaner will leave residue on can alos make sure the the dishwasher is clean after time they can build up lime and scale,calcium you can use any kind od dishwasher cleaner this may help
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I have a GE dishwasher; spray arm at the bottom does not rotate.
make sure that there is nothing blocking the racks, no big pots or pans, if thats ok then take out the bottom rack, u will see the sprayer, use something long, a screwdriver should do, u should see a slot in the sprayer at the bottom, stick the driver through it and give it a turn, it will loosen, take it off and make sure it isnt clogged, also, ull see a little cover that looks like a grate, take that off also and make sure it isnt clogged under neath
Feb 05, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes dirty
your chopper is the have to take the insides out of the dishwasher to locate the chopper.
Jan 22, 2009 | Hoover 24 in. DT999 Free-Standing...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishwashers Logo
598 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
