Question about LaCie (300740) 160 GB Hard Drive
Won't power up or down, just a blue light showing power.
This makes no sense. Can someone confirm my Lacie EDMini is defective: It won't power up or go through the power down sequence unless I turn the orientation of the device. Sometimes rotating vertical to horizontal and sometimes spinning it. Now I can't get it to power down any way I try. And it's not visible through the network. What do I do? It's been finicky since I got it a few months ago, but it has worked and has all my backup on it.
  • 1 more comment
  • Phil Tucher Jan 26, 2008
    The blue light is on, so the power is there... Do you mean buy a new power cable?
    I don't understand. the cable is a cm circle with 4 prongs inside. should i see if i have another one like it somewhere? (I doubt that i do?) The HD is less than 6 months old. Will they replace it? I can't be buying parts on eBay to see if maybe the repair will work. This is messed up!
    I don't understand. Does your company work for Newegg.com? That's where I bought the NAS. Their website says I have to go through this process first, but I do NOT want to have to buy parts and do this repair myself. I deserve a refund for this if it's a faulty power chord.
    How do I get my $10 back for this or get a solution that works for me?
    Genius:
  • 1,067 Answers
Try new power plug 1st ok report back
Posted on Jan 26, 2008
  • 3 more comments
  • nick helpap
    nick helpap Jan 26, 2008
    is it just likea reg computer cable that powers into it ? test off computer cable then justto make sure cable aint shorted inside the power to the hard drive could have tooka poo its easy to take it aprt and take that big hard drive out and buy a new case for it o n ebay also 20 nbucks thats goes usb works with any ide hard drive ok
  • nick helpap
    what going on is power to the extrenal hd no good u can take it part get that hard drive out of that houseing unit ok and buy new case opn ebay to stick that in so work great again u want link this will work
  • nick helpap
  • nick helpap
    u just wann replace the hhouseing not the hard drive it self ok
  • nick helpap
    thats what im ytrying to say its bad unit ok houseing of it take back to new egg then ok if u can still or im telling what u need to do ok
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Value of the memory capacitor on the PCB of the LACIE EDmini v2
If the voltage and the farads are higher than the original it won't make any difference what you put in. They are not much greater than 47uf, if you think it's 10uf than put anything above that in. It will really depends on the physical size of the replacement. Get one they same size as the one that's gone and you can't really go wrong.
Jun 19, 2012 | LaCie Computers & Internet
Hello. I have a LACIE EDMINI-V2 that won't start, no disk noises, no light from led in front button, nothing. I have dismantled the box, connected the disk drive to my PC and its ok, measured the 5V and...
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here: http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here: 503-844-4503 sales@lacie.com
Please leave feedback for this answer, thanks.
Mar 09, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie edmini 250 GB will not power up
sounds like a faulty power circuit within the external housing. remove all screws and the drive from its housing. you now hold in your hand an internal hdd. remove all jumpers, if any are present, and install this drive on the same cable as your master hdd. now when u boot up to my computer window, you will see two hdd named C: and D:
Jul 01, 2009 | LaCie (300770) 250 GB Hard Drive
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
No access to the disk, same clicking sound + constant light
It may not be getting enough power. Is there an external power supply you can plug in or another USB connector that can be plugged in to another port?
Jun 18, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
152 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
