Question about Kenmore 43142 Front Load Washer
The water is not being pumped out of my kenmore front loader washeer machine
The water is not leaving my washer machine which also makes the machine not go into the spin cycle. Do I need a new pump?
    Genius:
  • 1,554 Answers
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Posted on Jan 26, 2008
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | KitchenAid KHWS02R Front Load Washer
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Cleaning the washing machine
It is recommended by the manufacturer that you leave the washer door open on all front loaders when not in use or the washer can develop odors, or begin to mold and mildew. Leaving the door open allows the tub air out. Because this is the lowest point of the drain cycle, gravity will always cause residual water to reside in the drain pump and drain lines. The water will NOT evaporate, but it will keep it from becoming sour. The following link explains what some of the common causes of odors in a front loader are and how to prevent them:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Newer model Kenmore Elite, Whirlpool Duet and Maytag Epic have a "Cleaning Cycle" button on the front panel. The owner's manual will explain how to use this feature.
If you do not have a cleaning cycle, use the hottest setting you have about once a month with a small amount of bleach to keep the spin basket and wash tub sanitized. I recommend the "Whitest Whites" cycle set on the "Light". This cycle is only 48 minutes.
Read through the link provided and make sure you periodicallt check the drain pump for debris that can cause odors and make sure you are using the correct detergent. If you have any questions, please post back and let me know. I hope this helps you.
May 02, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Getting rid of a horrible stink in my washer kenmore HE2
The following link will give you some tips to try in order to minimize odors and mildew in a front loading washer:
Following a good regiment of routine cleaning of the door bellow, followed by leaving the door open when not in use (at a minimum) can go a long way towards preventing odors in a front loader. Since the doors on these washers are water tight when closed, it is importnant to leave them open when not in use to allow the drum to air out. There is a small amount of residual water that remains in the drain lines and pump that will sour if you don't. I personally own a Kenmore Elite and have never had problems with mildew or odor in the 9 years I've had it by following this routine.
In addition, it is a good idea to periodcially check the drain pump reservoir to ensure there is not dirt or debirs clogging the pump and becoming stagnant. The following link explains how to access and clean the drain pump (if necessary):
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
The drain pump reservoir collecting debris, along with small articles of clothing getting caught in the folds of the door bellow are the two main causes of odors in a front loader.
Read through the links provided and let me know if you have any questions. I hope this helps you.
Feb 05, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer leaks after replacing water pump
front loader or top loader we can not guess
Sep 13, 2017 | Kenmore Washing Machines
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
