Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool Gold dishwasher
Model #GU98OSCGQ2 The keypad is dead. Power is going to the keypad, but no LEDs come on and no buttons work. Door switches check good, fuse checks good. Replaced with a new control board, but that did not fix the problem.
  • 3 more comments
  • chrissey Feb 28, 2008
    Im having the exact same problem!! please let me know if you find a solution!
  • jh4uk May 31, 2008
    Yes.... i found the problem. It was a short common wire the at the door switch. Was losing voltage
  • jlbrock7 Aug 07, 2008
    I have a Whirlpool dishwasher model number du915pwpb2 serial number ft1212171 power is going to the unit but no lights will come on and the bottom is filled with water, will not drain.
  • Anonymous Apr 09, 2009
    I have a whirlpool GOLD and the same thing happened to me... There is water on the bottom, not much, but some and the lights wont come on on the keypad... we checked the fuse, the power cord, we can't find anything wrong with it... I don't want to call a repair man if I don't have to, any suggestions?
    I went to turn the dishwasher on and NOTHING, the lights weren't working, water sitting on the bottom, NOT much, but it's there, it looks like it stopped in mid cycle I guess.
    We checked the fuses, breakers, power cord, etc... NOTHING ...
    I can call a repairman, but I would really rather not if my husband and I can fix it ourselves.
    Any suggestions? Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
Did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Posted on Feb 22, 2008
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
I have a Whirlpool gold Quiet partner III. The Normal button of the cycle is blinking and I can't start the dish washer. What is going on?
most likely the door switch is not making contact or is faulty. Shut the door tightly and see if it makes any difference.
Please provide the full model number of the dishwasher in case you need further help.
Aug 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold dishwasher Model GU1200XTLB3 Problem: Heat stays on when washing ends. The only way it will go off is if the door is left open. This happens with every use. I have tried the...
Hello, Thank You for using FixYa. I will be helping you today.The relay on the control board is fused closed. Control needs to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool Gold Dishwasher Quiet Partner IV. GU Series. It has stopped working and there are no lights on the panel. We have checked the power supply and that is fine.
Hello & Welcome to FixYa
Press and hold the AIR DRY/RINSE ONLY button to reset the control, if you have already tried this and it is possible that the door was opened while in cycle then the first thing that should be checked is the door switch/lock assembly. You can take a hair dryer and try to blow air on that, if the problem returns then replacing the door switch/lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool Gold, had 4years,had to replace
Thermal fuse mounted to the control board see if you have power on each side of it checking from post to ground,if you got power going in but none going out it's blown,and has a more serious issue somewhere.
Aug 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher doesn't clean/drain.
sounds to me like a drain pump restriction or failure. let me know if this helps.
Nov 14, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
926 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
