Question about HP Photosmart D5160 InkJet Printer
Can't print onto 4x6 photo paper
My photosmart D5160 wont print onto 4 x 6 photo paper. The tray feeds in but then comes straight back out saying that it is empty, despite the fact that it is not.
I make sure that there is no paper in the main tray but it makes no difference.
Everything else on this printer is fine so what's going wrong????
  • 3 more comments
  • Anonymous Feb 24, 2008
    printer was totally fine up until i changed the cartridges-344 and 348.the 344 is an original hp cartridge which was 26.99 and the 348 is a cartridge world remake which isn,t registering an ink level on the little printer screen but when i install my original black344 it isn,t registering an ink level either. however i am able to print fine on the A4 paper.bye the way i also put my orignal old348 in and it made no at the minute i can only print on A4
    cant print from photo tray
  • Anonymous Mar 18, 2014
    the tray will not go into the printer without the plastic tray being assembled properly
  • Anonymous Mar 23, 2014
    I want to print off the full size main tray
    what is going on- I need to print from main tray
I just tried to post what i did to solve this but it doesn't look like it took
now you know how to feed the paper with the perforated edge facing you and the shiny side down, if you take the edge opposite of the perforated edge (pretty much the edge of the paper that you stick into the printer) you just curl that up, i just curled it up about the width of my thumb, i would play around with that.
It might help to understand if you take the back off the printer and get a flash light and try to print a photo, you will see the paper tray slide in and see it feed.
hope this helps
Posted on Jan 22, 2009
My photosmart 7280 was having the same problem - it turns out that a the paper was catching when it was trying to feed and after one or two tries to feed a sheet - it would back the tray out and ask me to load more paper.
I removed the duplexing attachment and watched it try to print - I could see that the the paper was catching on a narrow metal paper stop at the back of the photo paper tray. This stop is indended to ensure you don't push the paper in too far when loading the tray.  I took a long screwdriver and bent it back and down slightly:
From this:  ________|          To this:       _________/
Hope this helps - it was sure driving me crazy!
Posted on Nov 08, 2008
  • 2,351 Answers
Did you try this from HP.
I also suggest you remove the back door & clean the wheels with a clean no lint water dampend rag. Replace the door.
Posted on Jan 26, 2008
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
I want to print photos from my laptop onto four by six photo paper, and i loaded the photo tray with the paper, and changed the tray preference to photo tray, but it's still telling me that there's no...
You also need to change the paper type in printing preferences.You will find 4x6 and 4x6 with tab in th pull down menu where it says plain paper. Be sure to position the paper as far as it will go into the printer and close the paper controls to hold it there. Also fan it well before you put it in.
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
Nov 29, 2008 | HP Office Equipment & Supplies
HP Photosmart 3210xi All in one printer will not print 4x6 photos
Have you processed many print jobs through this printer? if so, you might be needed a maintenance kit. the kit will include new rollers that will help pull the paper into the proper feed paths.
Apr 30, 2008 | HP Photosmart 3210 Printer
Will not go to photo tray to print 4X6 picture
This is why Mac's are EVIL!!!! LOL, anyway try using the software, that comes with the printer, and tell it which paper type, and tray to use. Also try printing on a PC, and see if it works then, as you may have to live with this as the solution.
Feb 22, 2008 | HP Photosmart 3210 All-In-One InkJet...
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D5160 InkJet Printer Logo
1,211 people viewed this question
Ben Johnson
