Question about DVD & Blu-Ray Players
Audiovox 1708ES car DVD player
1 year old car DVd player. Main system works fine, but all of a sudden 2nd scren remains blank. All is plugged in properly. Can I get a new 2nd screen from somewhere cheap? Can't find any. Or should I just buy a whole new system? Thx.
SOURCE: Audiovox PVS3393 portable DVD player,
I called someone who wouldn't charge me.
Posted on Apr 05, 2008
SOURCE: Replacing dvd player/burner on iLo DVDRH04 DVD Recorder
I Have ILO DVRHD04 and my front buttons sto to work when i use the remote works ok... when the unit is of I turn on from the front paner works ok try to turn off from the front buttons is not work and the lite in the front go crazy only when i pres stop & play button and on fo button... what is the problem... The remote work ok play stop edit or recodring
Posted on May 09, 2008
SOURCE: Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: durabrand dual 7c dvd replacement screen
I have two slave screens for sale. If you need one let me know. They are both slaves but if you have a cracked screen on the main unit, you can very easily pull out the screen on a slave and install the LCD screen into the main unit as they are both the same. Most all models are completely interchangeable. No wires to solder, just three plug-in wires. Both slave units work great, garanteed. $40 + shipping (ea). Paypal accepted. timtrentb (at) hotmail. com.
Posted on Jul 03, 2008
  • 146 Answers
SOURCE: audiovox d1708 portable dvd player: DVD spins and says loading...
If it does it with all discs then the player is dying. If it is just the one disc I would say it is a bad disc. You can also see if there is dirt or grease or fingerprints on the laser pickup lens.
Posted on Jan 01, 2009
  • 303 Answers
SOURCE: Need AC Adapter #PA009UG01
click on hyperlink:
buy replacement ac power charger adapter Audiovox pvs33116
Posted on Jun 01, 2009
0 characters
1 Points
My VHS-to-DVD Burned Disc used to work and now it doesn't
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Audiovox 8
So you're saying that already tried a lot of DVD but none of them is working? but this was working fine before is that right?
Aug 26, 2008 | DVD & Blu-Ray Players
I have great sound on my Audiovox portable dvd player but no picture. Can you help?
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
May 16, 2011 | Audiovox D1708 Portable DVD Player
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
Dvd player won't work when plugged in with car adapter
1 st Check and see if you have power coming out the power plug.
2nd. Ckeck and see if the fuse is ok in the unit.
3rd Check and see if your cig ligter works in your power outlet.
Jun 10, 2009 | Zenith DVP615 Portable DVD Player
Audio yes, picture no!
You can try to reset the DVD player to factory setting. Go to the set up main page. Highlight preferences and press enter. Go to the defaults setting and press enter. This will reset the DVD player to the original factory settings. If this does not solve you problem you can call the Audiovox customer support telephone number. 1-800-645-4994 Give them the model number of your DVD player and tell them the problem you are having with it. They will be able to tell you how you can obtain service for your problem. I hope this information helps you with your problem.
Dec 17, 2008 | Audiovox D1210 Portable DVD Player with...
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Cannot read disc
prob. the laser i have an accurian(radio shack) portable dvd with the same issue. spin motor fires fine but says no disk. just because the laser "lights up" dosent necessarily mean the read section works also. if anyone has a solution to locate a suitable laser please post here as i have a ton of lasers from various drives etc.
Apr 18, 2008 | Audiovox D1708 Portable DVD Player
Audiovox Kids DVD Player not working
It sounds like the machine is not picking up the dvd disk anymore. Try tilting it backward by 45 degress or so and see if that help....a pain i know but had same problem with my player after my darling 2 year old daughter damaged eh? :)
Dec 28, 2007 | DVD & Blu-Ray Players
Multiple vertical colored lines on DVD player screen
check this out
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
DVD & Blu-Ray Players Logo
64 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
