Question about Frigidaire FRS26R4A Side by Side Refrigerator
REPLACING FRIGIDAIRE FRS26H7C ACTUATOR
I bought a new water actuator, successfully removed the broken one and put in the new one, but now I can't get the water hose back in through the hole--just no room to get your hand in there to get hold of the hose to push it through. What's the trick?
  • jtkoziol Aug 18, 2008
    Finally was able to get the hose in the hole but when I put it all back together now I have no electrical connection. Checked to make sure all parts were properly connected to the board but it still doesn't work.
  • charles7777 Dec 26, 2008
    How did you remove and replace the actuator?
    Scholar:
  • 42 Answers
Darlenek,
There is a trick of sorts. If you go to the bottom hinge of the freezer door you will find the same tube. Pull carefully and give yourself as much excess tubing to pull up through the door. Do not pull too hard or too much. This will give you more slack on the top end to work with. Once you get it reinstalled in the hole in the bracket, you probably will need to pull "carefully" back down through hinge to reinstall the dispenser bracket assembly.
I hope this helped you.
Please don't for get to rate me if I have helped.
supertechks
Posted on Jan 26, 2008
Leaking water periodically under the refrigiater
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Frigidaire FRS26H7C Side by Side...
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Replace water actuator
im assuming you replaced the water actuator,and now cant fit the water hose back into the holder??? try disconnecting the hose under the freezer door hinge, this will allow you to pull extra hose up into the dispenser area, then after remounting the face you can reconnect at the bottom
Nov 25, 2008 | Frigidaire FRS26R4A Side by Side...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Broken water actuator
order the new part and put it in.
Jul 10, 2008 | Frigidaire Refrigerators
After repairing water actuator, nothing works
If tou removed the door to make the repair` be sure you reconnected the electrictal going to the door assembly. at top or bottom of door.
Feb 24, 2008 | Frigidaire FRS26R4A Side by Side...
Replacing water actuator on side By Side frigidaire
trying to bring temp down on the fridge side.first i tryed to just turn the temp up. Waited over night no change. Went back to factory setting,still no change. Fridge still under waranty all ready has a new copressor and invaporator installed by fridgaire. The fridge is only a 03 alittle young to have these problems.
Nov 24, 2007 | Frigidaire FRS26R4A Side by Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
234 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
