Question about Hotpoint Ultima WF860 Front Load Washer
F01 flashes and machine not work.WF860P
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
  • 1 more comment
  • gunners99 Feb 23, 2008
    i have the same problem with f 01 code on screen but the water keeps going into the machine any solutions please
  • Anonymous Mar 27, 2014
  • john May 19, 2014
    check your motor carbons and replace them
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
Take out the plug first... change the motor carbons
Posted on May 19, 2014
  • 67 Answers
Motor triac short circuit check motor and module connections, if o.k poss motor fault
Posted on Mar 03, 2008
2 Suggested Answers
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Posted on Feb 16, 2008
Washing machine is flashing f01
F01 is an Electronic circuit board fault
I recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Oct 19, 2014 | Hotpoint Washing Machines
F01 on display wmpf722
f01 is module problem.
a new module will correct it.
Mar 23, 2014 | Hotpoint Washing Machines
Hotpoint WMF540 flashing F01
In general this would indicate a fault in the motor, actual wording from Hotpoint is
Nov 27, 2011 | Hotpoint Washing Machines
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
Mar 05, 2010 | Washing Machines
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint erorr f01
sounds like a faulty water valve regards jason
Jun 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
1,224 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
