Question about Akai LCT2060 Television
Flat screen tv akai
I have brightness & volumn & no vidio.
  • Anonymous Apr 07, 2008
    I have sound but a blank screen. Does anyone know how to fix this at home or do you think I will need to take it into a proffessional? Thanks.
  • 30 Answers
Try to chek the output tansistor.and also the video section again with the vedio IC.
Posted on Feb 02, 2008
    Champion:
  • 367 Answers
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
TV turns on. has back light, has audio but no vidio
this is not good, if back lights on and no brightness either a main board or something between it and the display panel itself.
Dec 23, 2012 | Vizio XVT553SV 55 in. LCD TV
I have a 3 year old Akai 42" plasma TV, model PDP4216M. It has developed a bright red, 2" wide line down the righthand side of the screen. What does this mean, and can it be repaired? The TV has not been...
I had one red line at the beginning, then another one the same red, then couple months and green one. I fixed it by replacing one of the board inside (140$) and the problem is gone. The same model PDP4216M. Any questions e-mail me at kogut26@hotmail.com
Feb 26, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
AKAI volumn
That is actually not really a problem mine does the same thing you just have to tap the button let it go and keep tapping till you get to the acciured volume. You cant hold it down or it will take off and get loud fast i leaned that when i first bought it. Hope this helps.
Dec 01, 2007 | Akai LCT2070 20 in. EDTV-Ready LCD...
Yellow filter over all cannels on akai flat tv (not tft/lcd)
Start by researching by your exact Akai model # on our
Fixya website = start with All Products>Akai> your model >
troubleshooting............................................T.
Nov 23, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai LCT2060 Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
