Nokia 6600 Logo
Posted on Jan 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Restart when i switch on my mobile the menu comes but after that the phones automatically switch off,what could be the problems
  • Anonymous Jan 28, 2008
    i have a PROBLEM WITH MY PHONE .MY NIKIA 6600 PHON IS REBOOT 5TIMES WHWN WE START THIS
Anonymous
Level 2:
Sniper:
  • Expert 111 Answers
  • Posted on Jan 27, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
111
Questions
0
Helped
180075
Points
262
This should do the trick...press star, call button(the green one), three, and power button all together while powering up your phone..press them until formatting comes out then you release them..note: don't release buttons until formatting does not appear....try and try until you succeed
K770i connect charger and auto shutdown and restart over and over
sony Ericsson k 770 come shutdown menu in automatically....and shutdown it.But no restart.....pleace help me
1helpful
My cell phone restarts itself
It seems that your Nokia E71 might be infected by virus. And because of this you mobile automatically get restarted. In the way to recover from the problem for that you need to connect your mobile to computer. Then scan both memory card as well as phone memory of your mobile with antivirus. I suggest you to try this solution first.
There might be a chance; you have mistakenly enabled the features named as 'Scheduled Power on/off'. Because of that your mobile get switch off automatically. So you need to disable this features. For that you need to open the setting of you mobile from main menu. Then select the power management option from there. Here you will get option 'Scheduled Power on/off', try to disable it. Please check out that.
If the problem exists even after all the viruses are removed from the cell phone and 'Scheduled Power on/off' option is disabled, I suggest you to visit the nearest service center of you Nokia E71 phone. If you mobile is under warranty then try to replace this mobile. Please try one of these two solution to sort out your problem.
17helpful
5answers
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
2helpful
Switch on, automatically switch off
repairmobiles.saaqi.com/3110c-lcd-display-back-light-problem/
Problem of hanging & many more...
your cell phone is infected with virus you want to HARD FORMAT, switch off your mobile phone 1st, then press and hold 3 keys at a time star key, green dial key, and no. 3 key. then switch on your phone.
do not unhold all three key's until nokia's logo come's [hand shake] . it's done. you have to select your city. mean's your phone is virus free now.
[get backup of your contacts and messeges before formatting or you will lose your data]
Automatically restart mobile sgh j210.
your mobile is virous effected . So you can go to the mobile hardware point and solve it .
Mar 06, 2009 • Cell Phones
6helpful
5answers
Automatic Switch off
i have a mobile of nokia 3110. i found a problem in it that it suddenly restarted again and again ?is it any virus problem or any thing else? if yes where i found its anti virus plese suggest
HAVE PROBLEM
weel I suggest you select a main sim on sim menu. Put your simcard in the left side if you have dual sim slot then open the cellphone, go to menu and select sim switch, then select the main switch. it will automatically restart your cellphone. after that you wait and see good signal bar and your operator logo what ever it is. now its ok. hope it will help you......
1helpful
2answers
My 3120 mobile is automatically switiching on and switching off
nokia 3120 auto of is the mobile software problem change sofware enjoy if when u go to GOTO then auto off that is also software problem
2answers
Troubleshooting
when you're phone automatically switches on without even touching the switch i think the switch button might be stuck,try having it changed or if not maybe the battery's the problem or maybe the software or hardware might be damaged
Jan 26, 2008 • Nokia 6600
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
