Question about Dryers
Remote control ceiling fan
I have a Hunter ceiling fan that is wired with a three way switch but also operated from a remote. When I turn on the wall switch the fan light blinks on and off and the fan makes a clicking sound like it is trying to switch directions. The remote will not operate when this is happening. It doesn't matter if the fan was off when the wall switch was turned off , it comes on when the wall switch is turned back on. Eventually (5 min) the light quits blinking and the remote will work.
  • 1 more comment
  • tophurlder Oct 04, 2008
    I have the same problem - when I turn the wall switch on, the lights flash on and off really fast, with a clicking sound, and the fan is stuck in slow speed. Remote doesn't work at all. I checked the wires and it seems to look fine.
  • cid6 Sep 22, 2009
    light blinks and the remote will not dim the light
  • Anonymous Mar 14, 2014
    Hunter Wall heater CM 600-S blower fan not working. How can I fix this?
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 44 Answers
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Posted on Feb 09, 2008
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
1,871 people viewed this question
Top Dryers Experts
