Question about Rio Cali Sport MP3 Player
Upgrader message? Hi, I just keep getting an "upgrader" message on my Cali Sport 128 player and now it won't even turn on. What can I do??
  • 1 more comment
  • Anonymous Mar 25, 2008
    I tried updating the software, drivers, etc but it is still stuck in "upgrader."
  • schaos21 Jun 30, 2008
    same problem upgrader message whats that about
  • Anonymous Aug 02, 2008
    The same "upgrader" message is stuck on my Rio Cali (256 MB, I think) when I turn it on, and I can't get it to do anything. My computer no longer recognizes it when I connect it with the USB cable, either. What can I do?
Follow instructions at this website. You need to reinstall the "operating system" on your player. It's pretty easy.
http://support.rioaudio.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=12
Posted on Aug 02, 2008
6ya staff
SOURCE:
My rio keeps saying upgrader when try to turn it on how do i fix this?
try hitting power and menu at the same time see if that helps because its usually what buttons put the player into upgrader mode and see if doing so has the reverse effect
May 27, 2012 | Rio Cali Sport MP3 Player
When I turn it on or plug into my computer it allways say's upgrader and thats it
Hi, You may need to update the software. If you can not just ignor it. Good luck
Jun 27, 2011 | Rio Cali Sport MP3 Player
Rio cali 128 mb yellow
J'Ai réussi à ouvrir un fichier pour que cela fonctionne
May 24, 2008 | Rio Cali Sport MP3 Player
Rio forge 512mb problem.
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=213
Download firmware update ( same for ALL Forge players)
Install upgrade (run program from your desktop)
Feb 16, 2008 | Rio Forge Sport Digital Media Player
Upgrader
can u upgrade the firmware and software uuse for it from the website maker ok save the update sto the hard drive then installl
Jan 26, 2008 | Rio Cali Sport MP3 Player
RIO MP3 PEARL stuck in UPGRADER mode
Your Pearl hard drive is probably broken. This is common because they are fragile. Replacing it is the olny solution if it is broken i'm afraid. Read my post: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon for more info.
Hope this helps,
Mowcius
Dec 29, 2007 | Rio Cali Sport MP3 Player
When this happens to me (it does every few months), I re-flash the software following the instructions that come with it. Then the annoying "upgrader" message goes away for another few month. I use version 1.33 in my 512 forge.
Oct 31, 2007 | Rio Forge Sport Digital Media Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Rio Cali Sport MP3 Player Logo
320 people viewed this question
Top Rio Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
