Question about Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric
Control panel fan won't turn off
Front fan,not convection fan won't turn off
  • 2 more comments
  • mobryan100 Jan 26, 2008
    the oven is cold and it has been hours since it has been shut off
    the oven cold and it has been hours since it was turned off even turned off at circuit breaker last night turned back on this morning and fan still running
  • mobryan100 Jan 29, 2008
    Thanks for the advise,but no change. Fan is still running after turning on the power to oven and then tapping control panel. Any other ideas.
    I didn't mean to close it out this is my first experience I just wanted to thank you. Should I post again
  • 770 Answers
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Posted on Jan 26, 2008
  • Gary Davd
    Gary Davd Jan 26, 2008
    you have a sticking relay lightly tap the control panel and see if it stops if not we may need to open the unit try that and let me know
  • Gary Davd
    Gary Davd Jan 29, 2008
    Well I was going to get into it deeper with you but you have closed this rating out now
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
F2 appears on the front panel and there is a fan that is running and won't turn off. What should I do?
F2 Oven too hot Check oven temperature sensor
The problem is either with the sensor or the wire between the sensor and the control panel.
The sensor is the metal rod that is inside your oven, it comes in on the back wall and is a little smaller than a pencil
Jun 28, 2011 | Magic Chef 9815 Electric Single Oven
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
520 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
