Question about Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor
Blank Power in on, all connections are good, but no image...just a blank screen.
  • playin0 Feb 17, 2008
    Connecting to a computer and holding it at an angle with a bright light worked.  I saw the "Dell Red, Green, Blue, White" box floating around.
    So that means the lamp  is bad?  What can I do?
  • nagarajsk Aug 16, 2008
    I have a similar problem with my Dell TFT 19inch SE198WFP monitor.i am able to see self-test Feature check(STFC - Red,blue, Green). Monitor runs fine on linux(fedora -8) with screen resolution 1400X900 but not on windows :(..
    Once is choose windows to boot, i can see the windows running for a while before the user prompt appears and then screen goes blank saying
    "Auto detect(Analog Input)
    cannot display This video mode
    optimum resolution is 1400 X 900 60Hz "
    This is same for Digital input.
    I am connecting through VGA, have 64mb V Ram, P4, 1.6GHz,512Mb Ram(SD Ram).
    Kindly please help me, all efforts went vain to reach tech support, really pathetic
  • 1,554 Answers
Unplug the monitor from the computer,
it should display the diagnostic screen on monitor in color.
if not reconnect it and boot computer or attach to a running computer with some stuff on the screen,
get a bright light and shine on the screen at an angle do you see the stuff/desktop.if you do the lamp or power supply is bad.
if the monitor is lit and the lamps work but no diagnostics then the video cpu on the monitor is bad.
post your findings here
Posted on Jan 26, 2008
  • Karl Whisenand
    Karl Whisenand Feb 17, 2008
    Normally that means the high voltage inverter that supplies power to the lamps is bad.
    its a plug in module in the screen.
    it requires taking the screen apart ,usually a easy job.
    the only real way to verify is to measure the voltages before and after that module, is it getting 12vots does it have high voltage output.
    or just order one on ebay or such.
    here is once for aroound 45.00
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
Sep 15, 2014 - Uploaded by
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
Mar 4, 2014 - Uploaded by
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Blank screen panasonic plasma tv
Plasma screen expired how old is it how many hours function does it have ?
Nov 17, 2017 | Televison & Video
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
The monitor screen blank / black and power on off switch flashes
You could check the VGA cable from the replicator to the monitor, but a problem with that will usually cause a "NO SIGNAL" message to appear. So your issue seems to lie within the monitor. It could be that the backlight has quit. That can be determined by booting the laptop and connecting it to the replicator, or perhaps to the monitor directly, and observe the screen using a good flashlight, place the flashlight flush on the screen in an area where you would expect to see an icon or some recognizable image. Look closely to see if the image can be seen. If the image is there, then the screen is ok but the backlight is out. The problem is usually the inverter. A reputable shop might be able to replace that.
Dec 15, 2008 | Acer AL2016W 20" LCD Monitor
Blank screen
Its inverter or mother board problem power which passes to backlight is cutting off because of over heart (over heart of some IC).
Sep 16, 2008 | HP Compaq Presario V2000 Notebook
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor Logo
244 people viewed this question
Alun Cox
