Question about Procom ML300TBA Heater
Ml 300tba too much gas useage
How much gas should this mod use? is 20 lbs too much in 12 hrs ?
You should probably try a smaller regulator, I use 25gal propane tank in 2.5 weeks
Posted on Feb 28, 2008
I have kaoplecin for horses. Dosage for foals is 15 mL for every 10 kg and for the mare is 30 mL for every 45 kg. The foal weighs 300 lbs and the mare weighs 1200 lbs. what are the dosages to give
1 kg is 2.2 lbs 300 / 2.2 is 136.07
136 /10 is 13.6 times 15ml = 204 ml
1200 / 2.2 is 544 544 / 45 is 12.08
12.08 times 30 equals 362 mls
Nov 27, 2016 | Cars & Trucks
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
Procom ML 300TBA Pilot will not stay on when button released
It sounds like you need to clean the contact on the thermocouple.
Here is a link to the service instruction of how to do that.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 12, 2012 | Procom ML300TBA Heater
How do i know who much time it takes to defrost a whole chicken?
Defrosting times for the Refrigerator Method 5 lbs -
7 lbs -
10 lbs -
12 lbs -
15 lbs -
24 hours (1 day)
34 hours (1 day 10 hrs)
48 hours (2 days)
58 hours (2 days 10 hrs)
72 hours (3 days)
Jan 25, 2011 | Microwave Ovens
I need torque specks for valve train for a 1987 nissan truk v6 3.0 litter
cylinder head bolts 40 - 47 ft lbs, intake manifold bolts 12 - 14 ft lbs. , intake manifold nuts 17 - 20 ft lbs. , rocker arm shaft bolts 13 - 16 ft lbs. exhust manifold bolts 13 - 16 ft lbs. i hope this helps.
Dec 22, 2010 | Nissan Pickup Cars & Trucks
I HAVE A CRAFTSMAN 1 HP 12 GAL AIR COMPRESSOR THAT WILL ONLY BUILD 20 PSI THE COMPRESSOR ONLY HAS 1.5 HRS RUN TIME ANY SUGESTIONS
hi there, if the compressor built up a 20 psig and run at 1.5 hrs.then stop.check the pressure switch the differential pressure cut in and cut out limit.adjust the cut out to the corresponding cut out pressure you want but not exceed to the designed pressure tank..this will be done on adjusting cut out pressure screw mounted inside the pressure switch.follow the instruction on the manuals adjusting pressure switch.the run time correspond to the cut out limit of the pressure switch. rate my fix if your satisfied thank a lot.
Apr 20, 2010 | Air Tools & Compressors
Recomende tire pressure touring motorcycle
Generally I put the front and rear tires @ 40 psi. You get better gas mileage , plus it rolls better when you have to push it around, but you also get better tire wear. I would set your rear air suspension around 12 -15 psi.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Mar 20, 2009 | Harley Davidson 2007 Harley-Davidson FLHX...
I WAS INSTALLING THE CYL HEADS ON MY JEEP 03 LIBERTY, THE MANUAL INDICATES A TORQUE OF 20FTLBS, THEN VERIFY, THEN 90DEGREES/ BUT THEY MENTION BOLTS 11-14 BUT THE HEADS ONLY HAVE 12 BOLTS?
  1. Step 1: Bolts 1–8 to 20 ft. lbs. (27 Nm)
  2. Step 2: Bolts 1–10 verify torque without loosening
  3. Step 3: Bolts 9–12 to 10 ft. lbs. (14 Nm)
  4. Step 4: Bolts 1–8 plus 1/4 (90 degree) turn
  5. Step 5: Bolts 9–12 to 19 ft. lbs. (26 Nm)
Aug 02, 2008 | 2002 Jeep Liberty
Heating & Cooling Logo
102 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
