The Nintendo Wii already comes with everything needed to play GameCube. GameCube disks are loaded and unloaded from the system in the same way that Wii game disks are used. To play the games you are going to need a GameCube controller and a GameCube memory card to save progress. On the top of the system (if the system is vertical) or on the side (if it is laying down) are two flaps, one which opens to reveal the controller ports and the other reveals the slots for the memory cards. To play GameCube, simply select the top left square from the main menu (like you would for any Wii game), select start, and then use the GameCube controller to play the game.
that is normal all it means is that your now using a game cube controller to operate your wii. Also, you must manually turn off your wii and reboot your wii to change games.
Well that depends if your trying to play gamecube games on the gamecube or the wii?, i assume your doing it on the wii because anyone would know that a wii control wouldn't work on a gamecube, not impossible, just very hard
wii remotes do work with the nintendo wii on wii games and on gamecube games, but it is better if you use a gamecube controller and plug it into the to holes under the flap, pictured below, hopefully.
Hello my name is Tim Ehrhart, Not all game cube games are compatible with the wii and some need a update to work, to do this update connect to the net using your wii and then put the game in. Most game cube games do work but unfortnately not all do. Please leave me feed back as I am new and need to build a good rep. Take care and feel free o ask me any more questins you have.
Two choices. One: If your console still has a warranty, send it in for repair. Two: Open up your Nintendo Wii Console and clean the lens of the disk drive with some rubbing alcohol and a q-tip. Then put the console back together.
