Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
52 inch Samsung hdtv
I have gone from 1 to 7 horizonal black lines on the screen in 6 months, I tried unpluging and rebooting the cable box and there is no change, I have heard that there may be simple solution, can someone help?
  • 105 Answers
I would check with samsung support/customer service that is usually a bad panel that needs to be replaced.
Posted on Jan 26, 2008
Have a samsung PN64D550 plazma with 3/4 inch black horizonal line. What is repair solution?? and is this something that I can do myself?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma TVs are given with screen-shots. You can get an idea about the fault to an extent.
Jan 11, 2015 | Samsung PN64D550 64 1080p 3D Plasma HDTV
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
BLACK SCREEN WITH A BRIGHT HORIZONAL 1/4 INCH
HELLO
This is called Field Collapse and usually caused by the frame/field output going open circuit and/or the componants that surround that part.
Call a service centre in your locality who put it right (:-)
Nov 22, 2009 | Sylvania Televison & Video
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
I have a Samsung 52 inch HDTV LCD television, my problem is that for about 3 days the screen says "One Moment Please" this channel should be available shortly. That is it nothing else for days I am not...
If you have a cable set-top box, then the problem is almost certainly in the cable box itself. If you have a cable card installed in the TV, it could get a little tricky. Either way, it wouldn't hurt to have the cable company come out to check your system for you, whether you need a new cable box, or to try a new cable card in your tv.
I hope this helps you.
Dec 29, 2008 | Samsung LNT5265F 52 in. LCD HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
RCA HDTV 52 inch television
If a DVD and the onscreen menu looks sharp and problem free, I would say it's the cable box. Since you only reset it, I doubt it has anything to do with the cables unless you removed them and didn't insert them properly or tight enough. Try a power drain on the cable box:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. This will also reset the cable box again, but draining the power can do wonders.
Oct 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
