Question about Kitchen Ranges
Faber agio range hood
We have had our faber agio range hood for 4 years, and we are having great difficulty replacing the flourescent lightbulb. We line it up and try to turn it to lock it into place, but the prongs of the lightbulb break. It sounds easy enough to do (we have never had problems replacing a lightbulb!), but we are really frustrated, having broken about 5 bulbs now. Needless to say, our friends are laughing about this! The bulb is in a very tight spot against the wall over the cooktop, and is difficult to get a tight hold on the bulb. Any suggestions would be welcomed!
Many thanks.
  • hi5acres Apr 27, 2009
    not exactly the same problem-we can get the bulb in there, but it blows as soon as we put it in.
SOURCE: How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
Posted on Dec 28, 2007
SOURCE: lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Posted on Mar 02, 2008
SOURCE: Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Posted on Jan 29, 2010
Testimonial: "Thank You, I'll give these a try!"
SOURCE: Venmar stove hood, plastic cover for light is broken
The part number for the 1200,1400,1600 & 1800 series is #01752 light difuser.
They all fit the same opening.
Try venmar-ventilation.com.
Also appliancepartspro.com.
Posted on Feb 27, 2010
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
Faber model inca hc 72. The fan makes an odd noise. It still works. it is 11 years old.
your hood probably needs a service call to examine the motor, please visit http://faberonline.com/service.html to find your local service #, thank you
Jan 30, 2014 | Faber Inca HC SS Stainless Standard Insert...
Faber range hood fan stuck
Can you start the fan while holding the motor? If it runs fine while not in the hood, then likely the fan is rubbing against something that is not letting it get up to speed. If the motor does not run when removed from the hood, then there's something wrong electrically - a start capacitor, bad motor, etc. Try to verify the fan is not rubbing on something first.
Jan 21, 2014 | Faber Kitchen Ranges
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Jan 19, 2014 | Euro-Pro Faber Axia Isola Plus Kitchen...
Can you suggest a good degreeser to clean cassete filters tried several products but not very effective
I"m not sure what you mean by cassete filters, unless it's two filters. I take mine out and put them in the dishwasher!! Works great, The grease comes out and they shine again after I take them out. It does not hurt them, I have been doing this for years.
Mar 25, 2011 | Faber (272607) Kitchen Hood
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
I got hood Faber Moda Lumia 90 ,and on display writes FF.What
I did not solve the problem,but I don`t have the money for your answer.I thought it is free.
Thanks.
Sandra
Aug 24, 2009 | Faber Kitchen Ranges
I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
May 26, 2009 | Faber Diamante Wall Hood
Kitchen Ranges Logo
138 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
