From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
What you have been told is correct, these proprietary systems are great for the manufacturer, but when they start to have issues (and they will) they leave you 2 options: pay through the nose to stay original or replace the amps with new ones....the upside of this is aftermarket amps are soooo mugh better than stock that it is lauhgable.
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go. The same goes if your have an aftermarket amp driving your speakers.
