Question about JVC HD-52G886 52" Rear Projection HDTV
JVC DLP FAN
THE FAN DOES NOT START WHEN I TURN TV ON
  • 58 Answers
If the fan doesn't start then this model will shut down and the power light and lamp light will blink at .5 second intervals. If this is not happening and your unit says on then I would not worry about it. If the tv overheats then it has other shutdown circuits to prevent damage. If your tv does shut down then a technician will need to replace your fan or fan controller board. You can also have them clean the dust out of the interior of the tv to prevent this from happening again. Hope this helps.
Posted on Apr 02, 2008
When i turn the tv on a green light blinks 10 times then it shuts off
The TV probably has power supply trouble. It tries to start but can't.
Jan 07, 2014 | Televison & Video
Fan issue
Only way to know is look to see if fan is on (set will shut down almost instantly if any fan slows or shuts off--the fans are all being monitored.)
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
I turn the Tv on and after 2 or 3 minutes the tv turn off and the blue light stay on and the red light start blinking
Most likely the fan in the rear has gone bad and the lamp is overheating and the system identifies this and shuts it down. Check to see if cooling fan is activating on power up.
Jan 12, 2011 | JVC AV-48P775 48" HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My tv keeps turning off right after i turn it on
I have a samsung dlp tv and had a similar problem. Fortunately, I also hava a samsung color laser printer that had a fan problem for which there was an easy fix. It turns out that the fix for the tv is the same as for the printer - oil the fans. It is really easy and takes about 15 minutes. You have to unplug the tv and remove the rear plastic plate( about 9 screws) The main fan is on the middle tray with the projection equipment. you have to remove two screws and disconnect four electronic connections to remove the tray. Then unscrew the fan holder and turn the fan over. Remove the sticker and place a little light maching oil on the axle. Give it a couple of spins and replace. Put everything back before plugging in and start the tv. It has worked great for me since.
Feb 17, 2010 | Samsung HL-S5086W 50" HDTV
TV will not turn on
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | JVC HD-61G587 TV
Remote will turn on the light, but not the fan.
I have a white Westinghouse tv and can not programs the code in a Rca universal remote control
could you give me the code for the tv. Thank you
Nardin
Jul 02, 2009 | Universal Remote Control Hampton Bay...
TV won't turn on, no status lights, nothing.
urn on you tv after it goes off
go to front press menu and device at same time
it will recycle and the green will start flashing
count the cycles a three flash pause and than a 7 flash
will mean a bad fan
there is fan in the back that cools a heat sink
it is easy to get to
sometimes the connection goes bad
you can check your fan
dont order one from mit
this is a standard 3 wire 50mm x50mm computer heat sink fan
take yours out and find one to match
cost about 6-8 dollars unless you have laying form old computers
you have to take off the plastic cover in the back no big deal
with cover off yu will see a metal cover looks like a tunnel at the bottom
three screws removes it wires are under
after removal you will see the fan and heat sink
put you filter on the side back on with the two screws
so that the tv will start plug it back in turn power and see if the fan spins
if not check connects no run after that
than replace this fan
mine worked fine with new fan
if need more help you email me at tileman22@comcast.net
Nov 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JVC HD-52G886 52" Rear Projection HDTV Logo
359 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
