Question about RCA RMW729 Microwave Oven
RCA Microwave stopped working
My Microwave stopped working last night... It is not getting any power & other appliances work in the outlet... Is there a fuse that I should change? The appliance is only about 6 months old and it is a RCA model RMW700
  • kvillarroele Nov 11, 2008
    I have the same problem RCA microwave RMW729
    Just stopped working, no power.
  • zenix420 Apr 02, 2009
    I have a RCA model RMW768 with the same problem. I opened it, checked the fuse and the fuse is ok. No power at all....dead. Bought it just 4 months ago.
  • 105 Answers
It probably just died they do that sometimes. you could take it back to the store you bought it, contact RCA or just throw it out and replace it with another.
Posted on Jan 26, 2008
This microwave was working perfectly last night and doesn't even look like it has power today. We have done nothing to it. Please help. It is a Kenmore 721.62624200.
First, check to see if the circuit breaker has tripped. Then check to make sure it is firmly plugged in to the outlet. After that, it is time for a technician.
Feb 24, 2015 | Kenmore Microwave Ovens
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Stopped working like it blew a fuse
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 08, 2011 | Sunbeam SMW777 Microwave Oven
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
My estate microwave tmh16xsq-7 stopped working, its like its not getting any power i know its not the circut because only the microwave is not working could it be a fuse on the microwave?
Hope this helps.
Jan 12, 2011 | Estate TMH16XSQ Microwave Oven
My microwave made a funny noice a couple of nights ago, but continued to work fine after that but now it's completely dead. Checked the breaker and it's fine. Any ideas?
YOUR SAFETY IS PARRAMOUNT!
Hope this helps.
Jan 05, 2011 | GE JE1640 Microwave Oven
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
RCA RMW729 Microwave Oven Logo
1,164 people viewed this question
Top RCA Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
