FixYa.com
Tags:
JVC MX-G70 CD Shelf System
No power (by 2 users)
posted by abel_theman on Jan 26, 2008
I plug in other speakers while system was on.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 11, 2008
It is the same thing, could it be that maybe that the power ic's damage?
Solution #1
Not Rated (0)
chie-chie
Rank:Wiz Wiz
Rating: 83%, 86 votes
u accidentally contact the chasis..with positive terminal of ur speaker..."short circuit" this may cause fuse to blow or cut
remedy:
..replace fuse... then swich on.....
Comment by chie-chie, posted on Feb 14, 2008
in case the power switch on and you hear only one channel replace IC.. from audio section..good luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
Looking for a standalone DAC,...
Any opinions on the Gefen unit?... Answer This...
Audio Shelf Systems
connecting my Kenwood Receive,...
We just moved and can't... Answer This...
Audio Shelf Systems
Sansui Hi Fi System MC-X5
I need the following spare part... Answer This...
Audio Shelf Systems
Philips micro system model...
Micro system instructions and... Answer This...
Audio Shelf Systems
pmc r35l micri hifi
lcd backlight fails to... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
