Question about Kitchen Ranges
STOVE elements To whom it may concern: I am having problems with my stove: one of the elements heat up fast and burns my food the other takes forever to heat up (smaller ring) I've looked at them but I don't see anything burnt out? I appreciate your prompt response. Kevin Reid reidcom@rogers.com
Thanks mate I'll hav a go at that
Posted on Sep 15, 2012
    Scholar:
  • 72 Answers
It is your infinite switches. Replacement is the only option. Find the model number and go here to find parts.
www.appliancepartsdepot.com
Hope this helps.
Posted on Jan 28, 2008
Kenmore 911.9562991 glass top stove-glass cracked
I have Yamaha RX-v473 can not turn on , I try tone+info+power still not working. It’s have other way to turn no power ?
Oct 23, 2017 | Kenmore Kitchen Ranges
OVEN WANT HEAT PROPERLY FOOD DOSEN'T GET DONE
It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter or take it to a store that sells replacements ($25) and they may check it for you.
Oct 31, 2009 | Kitchen Ranges
Whirpool Imperial Series Stove turns off while I'm trying to bake
there is a control board just behind the clock. on that board is an omron g2rl-1a-e-cf, 9vdc, 16/250vac type relay. i replaced that relay with an equivalent wired in one and that fixed the problem.
Jun 19, 2009 | Whirlpool GR460 Electric Kitchen Range
After installing the pellet stove,the stove seems to 'burn up" the pellets to fast not creating a "coal bed ',no real heat is going in the house.It is a breckwell big E mod. 55'000 btu...
Not sure what is happening but if the pellets are burning too fast that tells me you have to set the air flow while they are burning. Even a wood stove will burn to fast if there is too much air . There should be a setting for the air flow on all stoves and some times it should be almost closed. if it continues i would contact the stove seller and ask them.
Sep 04, 2017 | Heating & Cooling
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
194 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
