Question about Cerwin Vega XL 600.1 Car Audio Amplifier
Amp gets hot
I have a cerwin vega 1200w exl1200d amp and it is hooked to 4 12'' pioneer champion series subs. It plays find but the amp gets hot and cuts in and out. Any help that you can give me will be greatly appricated.
    Genius:
  • 1,139 Answers
Check your speakers to make sure that they are the proper Ohmic value, and make sure your grounds are secure.
The unit is dissipating too much heat which is a sign of an impedance mismatch. In other words the full power output is not being delivered to the load (speakers), rather it is being dissipated in the source (amplifier) which as said is a sign of an impedance mismatch.
Thank you,
I hope this helps
Shuttle83
Posted on Jan 26, 2008
6ya staff
SOURCE:
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Sub amp was working fine then died,all circuits "look" fine but op amp running real hot.
did you check the fuses on the sub amp. all amps and sub amps and subwoofers have fuses. look in your book to find where they are and you can get the fuses at radio shack
Jan 13, 2010 | Cerwin Vega HTS15A Subwoofer
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
I HAVE A CERWIN VEGA CLS-15S POWERED SUB AND A PIONEER RECEIVER WITH NO RCA SUB HOOK UP ON BACK. HOW DO YOU HOOK IT UP
flathead30,
This is an old question but if you have not yet figured anything out, hear is a suggestion.
Without buying any other electronics, use your tape output on the receiver and let your sub's built in crossover to filter the highs out of the signal.
-Chris
Apr 16, 2009 | Athena AS-F1 Main / Stereo Speaker
I am buying a pioneer vsx-d414 receiver and want to no if it will drive my cerwin vega e-712 speakersv says for receivers rated 8ohms or lower.. , just currious
Yes the Pioneer will drive the Cerwin Vega speakers. The Pioneer requires at least 8 ohm speakers and if the Cerwin Vega speakers are 8 ohms, it won't be ******* the receiver.
The speakers you have are high wattage, so the Pioneer may not be able to get the most out of them, but it should be pretty good.
It is always good to have speakers rated at a higher wattage than the receiver, that way the receiver will not fry the speakers. No matter what the wattage of a speaker, it will not pull more power out of an amplifier than the amplifier is capable of delivering. Some people have a mis-conception that if a speaker is higher rated that it will blow up the amp, this is just not true. Speakers do not pull power from an amp, they only put out as much power as the amp is pushing into them. But you can blow up an amp by driving it too hard for too long of time. They just get too hot and the heat stresses the amp circuit after a while.
I hope this helps.
Dave
Jul 18, 2008 | Audio Players & Recorders
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Cerwin Vega XL 600.1 Car Audio Amplifier Logo
116 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
