Question about Creative Labs ZEN Vision:M Digital Media Player
Zen Vision M
When I turn on my zen vision M, when I see is the screen zen vision M and never turn off even when I try to reset the system. Can you help me on this please.
John
If you reset it and it goes back to just the zen screen, then I had this problem once too. You need to go to recovery mode (which is still possible).
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
    If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon Zen Vision M - vision_m_reset.jpgand hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole,
press gently and remove.
It will display the following options.
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.Here's the link to the site where I got the info from. (it's another forum). Good luck!
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=151527#M151527
Posted on Jan 27, 2008
My zen vision m player is stuck on lock
check the hold button...is it set to on position..?
Sep 11, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen won't turn on it's vision m 30 gb and when you plug it in all it dose is flash It doesn't pop up or even say anything in my computer PLEASE HELP
I am unable to reset my ZEN Vision M player. It will not even connect with my computer and the battery is completely dead. Is there a solution?
Jul 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
Creative Zen Vision M stuck when turning on.
If it is under warranty, get it replaced. The firmware is corrupted and unless the computer recognises it, you can't restore the firmware. If you can get it to come up to the maintenance menu you may be able to reset the player.
Best wishes
Jan 31, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M 60GB
Go to creative's website, they have an auto fix tool.
here ya go^^
http://us.creative.com/redirect.asp?id=5857
Jan 09, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
90 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
