Question about Kenmore 43142 Front Load Washer
How to clean the filter of my kenmore front load washer
How do i get to my filter and whow do i open it?
  • equerystrian Feb 03, 2009
    I have removed the panel that is below the washer drum, and I don't see anything that looks like a filter. I see motors and wires, but no filter. Help!
    Genius:
  • 1,554 Answers
Underneath the washers front edge are 3 screws remove and access panel will allow you to get to the large filter that unscrews.
be prepared for some water. use a small pan or lots of towels.
unplug the washer from AC first.
Posted on Jan 26, 2008
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
Kenmore HE2 washer stopped in teh middle of the washing, no power and can not open the door. Please help me in opening and fix it?
All frontload HE washers have a rip cord you can use to manually open the door but try to clean out your pump filter first. Your tech sheet is also there behind the service panel. Simply going by the diagnostics and cleaning out the filter could save you a bunch od money. Here is a nice video which shows how. H.E. PUMP FILTER CLEANUP
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washer smells moldy even though the door is left open between batches Could the filter need cleaning?
no filter there to clean need to visit smelly washer.com and run that stuff thru a cycle
Jul 28, 2010 | Kenmore 45081 Front Load Washer / Dryer
F 02 code is showing on my kenmore elite he3 front load washer - the washer will not open
take kick panel off
3 torques screws t15 or 7 milli meter
clean pump filter
if this does not solve your problem
replace your pump
Feb 01, 2010 | Kenmore Washing Machines
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Kenmore 43142 Front Load Washer Logo
959 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
