Question about Philips HTS3440/37 System
Home theatre turns on just fine, but after 10-15 mins a buzz sound comes on and the subwoofer fan comes on and it stays that way! Any advise would be greatly appreciated.
I had this same problem. All I did was switch the sound type by repeatedly pressing the "SURR." button on the bottom left corner of the remote. Usually after 10 times the sound is back,
Posted on Aug 12, 2008
Problem with sound - Philips HTS3455 Home Theatre System
Hi, I am sorry to say that there is probably a fault. First check the fuses if able (a possibilty). If not that then will need to go in for repair.
Hope that helps
Jul 24, 2009 | Audio Players & Recorders
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
F61 error message
NEED TO CHECK YOUR FANS AND THEN UR AUDIO STAGE.
Mar 27, 2008 | Audio Players & Recorders
Home theatre /philips hts 3440
might be over heating take blower to inside clean the fans well put it in well vented area cheak conections
Jan 26, 2008 | Audio Players & Recorders
Home theatre subwoofer
Sounds like you have a loose signal lead. Check to see if this cab be tightened if not replace the cable as this could be the cause of the problem. Over time the leads/plugs do loosen especially on subs as they vibrate so much. If it's not this then it's probably something internal to which I am reluctant to advise you on looking at yourself unless you are pretty proficient with electronics :P
Nov 08, 2007 | Jensen XS-1010 Car Subwoofer
Kef Kit 100 Subwoofer Buzz
i got the same buzz problem
Oct 26, 2007 | KEF Audio KIT100 System
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
Philips HTS3440/37 System Logo
233 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
