Question about Epson Stylus CX7800 Color Flatbed All-in-One Printer
Scanning lamp The lamp will not come on to scan or copy.
  • Epson Master
  • 1,879 Answers
Lamp is busted, better check your date of purchase for warranty.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Posted on Jan 26, 2008
Hi Sir I Have Problam In Ir 8500 Machin error 220-000
E220
1. The scanning lamp is turned ON during stand-by.
2. The scanning lamp is turned OFF during copy operation.Related exposure
try to clean up that area
May 16, 2018 | Canon Office Equipment & Supplies
My mfp m1132 is showing error E8 and cant copy/scan. what do I do?
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
Oct 07, 2015 | HP LaserJet Office Equipment & Supplies
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
Scanner not woking
If you can make copies but you cannot scan documents to folder or email then I would consult your resident IT person. If you are not able to make copies but the machine prints then you have a bad scan lamp. If you are not able to make copies or print and the scan lamp is as bright as can be then your laser unit is shot.
CANON IMAGE CLASS SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | Canon imageCLASS D1120 Copier
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
IR 400 E220 in Starting Machine
these means that you have problem with scanning lamp or scanning section.
Open the document cover and turn ON the copier, see if the lamp will glow, if not, probably you need to change the scanning lamp, but if it glows and you still has the E220, remove copy glass and put the scanning lamp in home position ( to the left side ) - NORMALLY BEFORE REMOVING THE LAMP TURN THE COPIER OFF AND PULL THE POWER PLUG FROM THE POWER OUTLET!!!!!
Hope that helps!
Apr 25, 2011 | Canon imageRUNNER 400S Copier
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
My HP 7110 Officejet says ''scanner failure.'' It will not let me fax or copy. How do I fix this?
If you can remove the glass, you need to clean the lamp and mirrors in the scan assembly, this error happens after the lamp ages and dust gathers on the scan mirrors. It's very expensive if you can even find a new scan assembly.
Jun 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Canon np6050
Dose the scanning lamp come "ON" when you make a copy. If it will not come "ON" your scanning Lamp is blown and needs to be replaced. When the scanner lamp blows you will get blank copies..
Dec 18, 2008 | Canon NP 6050 Copier
Scanning problem
Possibly there is a key that locks the engine that moves the scanner lamp, and that key may be locking the engine, and when the scanner try to move the lamp, the locked engine overloads the circuit, and turn off the device. Search for that key, and unlock this, (if it´s really locked).
Apr 18, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Epson Stylus CX7800 Color Flatbed All-in-One Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
