Question about Sunbeam Heritage 2346 Stand Mixer
The head will not realease
I have pushed the button and the head will not realease to let the head go back what can I do
  • Dee Dueser May 15, 2008
    The tilt release won't work. I cannot tilt the head back, therefore can't get the beaters released or the bowl off the plate. I have cake mix in the bowl!! Help!!
    I cannot get the head to release on the mixer. I have tried pushing the button over and over, plugged in and not plugged in. I cannot get the beaters or bowl to release because the head is stuck in the down position. Please help ASAP!
I had this happen while I was finishing my Christmas cookies. (note: unplug the mixer!) After reading some other posts, I undid the screws on the back of the mixer and removed the plastic parts to look at the inside. The nut on the bolt that connects the stand to the mixer body was really loose. I used a set of needle nose pliers to tighten the nut to the locking washer. Once I did that the button to release the body worked just fine! I put the reassembled the back parts and plugged it in to make sure it worked. There were 8 screws I had to take out before I could remove the knob assembly and get to that bolt and nut. Hope this helps!
Posted on Dec 30, 2008
How to remove beaters from Sunbeam Mixmaster. I see no release button.
On a Hand Mixer
Push the speed control wheel PAST Off. Push Forward
Release Beaters
Off
One a Stand Mixer, it is specific to the model. All the manuals are here
http://www.sunbeam.ca/en_CA/service-and-support/instruction-manuals/kitchen-appliances/mixers/kitchen-appliances-stand-mixers-manual.html
Button A on this one on the side of the head.
http://www.sunbeam.ca/on/demandware.static/-/Sites-sunbeam-ca-Library/default/dw20734b3d/documents/instruction-manuals/2379%20Stand%20Mixer%20IB.pdf
Apr 28, 2018 | Sunbeam Food Mixers
How do you tilt the back up on the k45 kitchen stand mixer?
To raise the head you move the locking lever back & lift the front of the motor unit up. To lower it you also move the locking lever to the back and then lower the head and release or push the locking lever forward to lock the head down while using it.
Mar 16, 2015 | Food Mixers
My kitchen aid stand mixer startnig making noise and wobbling. I noticed that the pin attaching the top to the base has been pushed out halfway and I can't push it back. Any solutions?
Remove the bowl, turn it upside down on a towel, look up inside the pedestal. Right in the middle where the hinge pin goes through there is a screw, unscrew it a little, push the hinge pin back to where it belongs and then tighten the screw up tight. Turn mixer up the right way, raise head up, fit bowl & flat paddle. Lower head & turn machine on low, listen for paddle tinging on bowl, if it is touching turn off and raise the head. Look into hinge area from the front, that screw is the head height adjustment. Clockwise to lower paddle in bowl, anti clockwise to raise. You want to lower it until you hear the paddle tinging on the bowl & then raise it enough to clear without tinging. You don't wind the screw in & out huge amounts, 1/4 to 1/2 a turn at a time is plenty.
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Head wont lift
THERE HAS TO BE A PIN ON THE SIDES OR WHEN YOU PUSH THE TOP BUTTON IT SHOULD TILTCHECK IN BETWEEN THE HEADS THAT DOUGH IS NOT CKED UP AND GLUED IT TOGETHER
Mar 07, 2014 | Food Mixers
Detaching bread hook from machine
Im sorry if this doesn't help (if it does please rate :D), but my mother used to have an older one and the way hers came off was by holding the dough hook tightly while pushing it straight up(wich in turn is pushing the dough hook into the machine head itself) while pushing the hook up give it a ( I believe clockwise) turn and let it slide off, don't drop it lol.
Hope this helped you!
Ps there is the lever on the side that once slid, releases the 'head' of the mixer, so you can tilt it back first, this should make it easies even.
Feb 03, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Can't attach ice cream maker dasher
If the bolt is the hinge pin that the head swivels on when tilting it up, it can be pushed back in when the head latch is released and the mixer head is lifted slightly.
Jan 17, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Beater is stuck on mixer
Poor some wesson oil into attachment socketin the head and work it a little by hand ----Unplug first. Work the release button and attachment.
Oct 26, 2009 | KitchenAid 32685 Mixer
Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
May 31, 2009 | Hobart H600 Stand Mixer
Oster Regency kitchen center question
Look under the mixing head on the bowl side. There's a square "tab" that looks like the one on the back side of the machine. Pull it towards the bowl to release the mixer head from the base.
Oct 14, 2007 | Food Mixers
Sunbeam Heritage 2346 Stand Mixer Logo
253 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
