Question about Frigidaire FEQ1442ES Electric Dryer
Dryer died A long wire was in my laundry and got caught in the holes at the back of the drum. The machine eventually made a horrible rumble and tripped the breaker. I flipped the breaker, removed the wire. It would tumble but no heat and maybe no blower. Eventually the breaker tripped again. I have the front off and don't know where to proceed- can I do something besides call a Professional? I am relatively broke...:)
  • allisanne Jan 27, 2008
    You are FABULOUS! I can't thank you enough! Bravo!
    President:
  • 1,314 Answers
Yes un hook the belt stand at the side of the drier grab the belt with one hand and the front of the drum with the other and kinda give a quick jerk up this should disengage the drum but be careful as stamped sheet metal is sharp it don't take much to get the drum loose then pull the drum out of the front of the drier behind it you will see the heater pan and you will find the wire shorted the heating element (by the way that was a underwear from a bra ) go to the appliance parts store and you can just replace the coil don't need the whole pan just follow the instructions in the kit a tip when you take the old coil off after unplugging the wires off grab the old coils as close to the cermanic block and bend them back and forth to break the ends when you put the new one on don't stretch it just insert one tab in the cermanic block bend the retaining tab one will do take the coil around putting it on its insulators it will fit no need to stretch then put some lithium hi temp grease in the rear bearing before reassembling the drum while your in there check the rear bearing for wear can get a kit for that too dont forget to rate me every time some one does that it lowers my ratings and i have to stop answering people
Posted on Jan 26, 2008
  • robert samples Jan 27, 2008
    im more than happy to help thanks for the kind words
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Horrible rumbling from back of drum. I have dissconnected all the pipes and power lead and removed the top. When i spin the drum by hand there is a horrible rumbling from what seems to be the back where...
roy, it sounds like the bearings are completly worn out. Its not an easy repair and if you decide to repair it leave it to the service tech.
to fix this properly a full new back section and shaft is needed which can be pricey but if your machine is under 5 years aprox £100 will fix it through the hotpoint parts warenty.
if over 5years aprox £140 will fix it again through hotpoint.
hope this helps you out
Apr 03, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
The dryer works, but now it makes a horribly loud rumbling noise. No squeaking or grinding - just loud!
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 13, 2009 | GE DBSR453GB Gas Dryer
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Bra wire caught in back of tumble dryer drum
We got a bra wire stuck in ours it actually went through the tiny holes at the back and bridged the earth and live on the heater coils, and the rcd kicked in to cut it out before it could of caught fire. Never in a millions year would you think that could happen !
Jul 25, 2009 | AEG Dryers
WM won't spin after sleeve got caught in door
I had this happen. The drive belt had come off. Just take off the bottom panel from the back and reattach the belt.
Jan 27, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My dryer is making a horrid noise
belt would squeak. but a horrible noise would probably be coming from the gear box. it may need a simple lubrication to the worst of replacing the whole gear box.
check it underneath the tub. if you can remove the housing and run it while it is open and see or hear where the noise is coming from. be careful on the moving parts once it is running with out a housing.
tnx 4 using fixya,
drcool
Nov 08, 2008 | GE DBSR453EBWW Electric Dryer
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
65 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
