Question about Sony PlayStation 2 (PS2) Console
PS2 Green LED remains on, system won't turn on
I have tried replacing PSU, checked all fuses for continuity and replaced eject/power ribbon and buttons. What is wrong?
PS2 is v4
  • needitnow Jan 27, 2008
    thanks for reply, but that is definitely not the problem. there was originally a blown fuse at #PS1 on the motherboard, which i replaced. now when i switch on the system from the back it goes straight to the green light. pressing the reset/eject button does nothing. no fan, no disc spinning.
    anyone shed some light on this?
    of course, i want to fix this myself, so to rephrase the question: how would sony repair this system?
  • 167 Answers
Have you tried holding down the reset button to turn off your console. Months before I bought my Ps2 I noticed my friends turning off their PS2's using the switch on the back. When i bought mine , months later i was invited to a friends house and noticed when he turned off his ps2 by holding the reset button down for a few seconds. After playing on their trampoline i went home and tried this reset button thing and it worked. Although i had the fat bulky ps2 this trick also works on slimline models too. This should solve your problem. The switch on the back i later found out was for when you wanted to turn off your ps2 during a thunderstorm.
Posted on Jan 26, 2008
  • anonymous anonymous Jan 27, 2008
    you may need additional service from sony
    um you might have a loose connection with the power/reset/eject ribbon cable
When I press the power bottom the orange light is just blinking
First thing you do is try reseating the ATX Connector (the 20pin white connector that gives power to the motherboard from power supply)
If this does not fix the issue, then disconnect all the components
(strip the system to MPP i.e. motherboard, psu & proc) and then switch on the pc to check if there is a green light.
If there is then switch off the pc, add a component & restart to check the green light exists.
Do this for the remaining components one by one to check which component is causing the issue.
If there is still orange light then check if the psu fan is moving.
If it does not move at all, replace psu. If if moves a little bit, connect just the dvd drive & check if it ejects.
If it does then replace motherboard. If you are replacing motherboard or psu, replace the front i/o panel assembly (the power switch assembly) for safety reasons.
Its inexpensive.
hope this helps
Aug 28, 2012 | Dell OptiPlex 360 Desktop Computer
What do that mean if yor ps2 tuns green then go back red
is it a slim PS2?
did it shock you when you touched the standby button?
if so, just unplug the power cord from the wall and wait a couple minutes before plugging back in.
hope this helps :p
if not, then you might have to replace the power/eject ribbon cable.
maybe someone more knowledgeable has better suggestions?
Oct 18, 2009 | Sony PlayStation 2 (PS2) Console
Bad power supply?
Do yo have a volt meter or an atx psu tester?
you can check voltage to see
If a power supply is bad, your pc will turn off or/and turn on and turn off. As long as your system is running without and shut downs your good.
However if your pc is turing off, I would change it as soon as you can. basically what is happening, when you unplug everything there isn't much of a draw on power so the light remains steady, but when you plug devices in there is a draw and the PSU cannot deliver.
I hope this helps.
Sep 07, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Don't want turn on and the power light flash red ,green
The LED flashes means that the set is in protection, Until unless the problem not removes the protection system keep activate,
First you have to check power supply unit, Check it properly if you have service manual then first check fuse, if fuse is burnt then replace it and if not then proceed check all the capacitors especially main capacitor, check STR also.
The above said components must help and solve the problem,
Thanks for using fixya.
Jul 01, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
PS2 will not power up.
Hi Willjan1,
Your motherboard is shot. You need to get another motherboard and install it.
Jan 28, 2008 | Sony PlayStation 2 (PS2) Console
GREEN LED WILL NOT LIGHT
the ps2 connectors are shorted so the mobo out highly recommend replacing mobo
Nov 26, 2007 | EliteGroup P4M800PRO-M Motherboard
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Won't boot up, can't eject disk tray
buy an xbox i mod them and have absolutely no problems
Jun 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
108 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
