Question about Acer AL1717 17" LCD Monitor
Acer Monitor AL1917 W
I have plugged in the monitor to the computer, but it won't work unless you turn the monitor on then turn the tower on. Is this normal for these types of screens?
    Sergeant:
    Champion:
  • 317 Answers
Yes.
When you unplug the data cable from the PC, you should usually get a 'no signal' message from the screen itself.
Other LCDs (like in this case), you have to plug it in and turn it one slightly before your PC goes on, so it can auto-adjust to the resolution your PC has.
Posted on Jan 26, 2008
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled somewhere...like TV/HDMI/VGA ...you are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
Hi! i got a acer al 1917 screen home from work, it seems fine when i start it and the acer startup screen comes up on display. but there it ends, when i plug it in, my cpu reacts on there is a screen...
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
Mar 31, 2011 | Acer AL1917 LCD Monitor
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
AL1917 LCD Monitor: IT SEEMS THAT THE MONITOR DRIVER HAS BEEN UNISTALL...
The monitor drive is only for allowing the resolution and some color adjustment that the OS may not have, the scrolling problem more like to be the PC mouse or setting problem.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Acer AL1917 LCD Monitor
Solution for more resolution
The native resolution for this monitor is 1280 x 1024 @60Hz, your PC should easily be able to put out this resolution, unless you do not have correct video card driver installed.
Post back if you are not clear.
Apr 21, 2010 | Acer AL1917 LCD Monitor
I need to know how to remove the footstand from my acer al1917 monitor pleas.
The wide black cover that seems to be part of the monitor on the back is in fact removable. Put your fingers/nails on the small gap on the underside and pull. There is some resistance but it is not too hard. Then you find 4 screws. Unscrew and voilà ... fixed!
Oct 20, 2009 | Acer AL1917 LCD Monitor
Acer AL1917A monitor freeze
acer al1917 go blank when change program
Apr 24, 2009 | Acer AL1917AS (Black, Silver) LCD Monitor
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Acer AL1717 17" LCD Monitor Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
