Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Raster no pic or sound
Hello silver i picked you because you look like you have a lot of experience.
The tv is a GE chassis TX808R it has a blue screen, no pic or sound
I am a beginer and this is the first time that I see this problem.
God will bless you more if you help me with this problem.
thank you
canichi.
  • ichican Jan 26, 2008
    It stayed on channel 69 the up and down button din't have any effect,so I plugged my VCR to the tv and the tv played the tape that was on the vcr. It took the signal in the channel that was marking the tv that is 69.After that the up and down button worked,
    Genius:
  • 1,554 Answers
Does the menu work?
Posted on Jan 26, 2008
  • Karl Whisenand
    Karl Whisenand Jan 26, 2008
    If you push the tv/video button on the remote you should get it to the proper cable input.
6ya staff
SOURCE:
How to fix JVC 21" Tv no raster
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 22, 2016 | JVC AV-A21M3U 21" TV
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
Chassis buckled on babystyle oyster travel system
Try ebay I can usually find all sorts of replacement parts or someone selling the whole thing cheap so you can use what you need
Apr 05, 2013 | Babystyle Oyster Travel System Includes...
Can get power but no picture or sound
Is your Tv Raster is there? if not probably your Horizontal section of tv not functioning. Check the B+ first.
Jun 01, 2009 | Sanyo HT27546 TV
Sound problem
  1. no picture &no sound raster ok.
  1. your problem is in tuner to vif section.
  2. check supply to TUNER & VIF section .
  3. check loose contact in above section.
  4. check components in VIF section.
  5. for ckt open the web site & download it fron there as given here.
  6. hope this will help.
  7. good luck.
http://www.eserviceinfo.com/index.php?what=search2
Oct 11, 2007 | Televison & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Vide problem
I think you have a problem in the vertical circuit in your tv. It sounds like you have a loose solder joint. The set would have to be taken apart and re-soldered. You really have an RCA chassis inside your tv. RCA's have a lot of bad solder connections. Stargazer
Mar 01, 2007 | GE 31GT740 31" TV
Pic Bleeding
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured. this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits. if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. but if you dont know anything about this, just bring it to a qualified service technician. good luck!
Jan 21, 2007 | Sony KV-35S45 35" TV
No raster, No sound, No channel number
wepu, Buddy it sounds like you got a power supply problem. As you say the picture is all blue?? With no video or sound and the fact that the channel display is out is the first indication that i would guess this. Do you still have the owners manual that you got when you first got the set? Good, cause thats the only place i can think of where to look in case of service over in your part of the world as I did try!! Man I tryed but to no avail. No one has heard of this model but that dosent mean that it dos'ent exsit!.. If your a tech or know your way around solid state circuitry then you should have no problem finding the fault once you get a service manual from the service location in your owners manual. Now if your not a tech and a handy man ?? If I were you I wouldnt mess with the tv as theres over 25000 volts inside the set and i've seen it make a grown man cry. Man dont attempt the repair or troubleshooting if you dont have the right or proper tools and equipment!!! Good Luck
May 26, 2006 | Philips 21PT4475 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
