Question about Compaq Armada 1750 Notebook
Startup Problem My Compaq Armada 1750. When it starts up it gets past the compaq screen, then it goes blank, and will not boot from cd, floppy disk, or hard drive. i cant access the F10 Setup menu. i think its a no go. i've seen problems like this before but never quite this bad. how it started: it is running Win XP. i started it up and was using it normal (like i'd always use it) and it froze so i tried rebooting it and that's when the problem occured. Please Reply, and thanks for your time.
    Genius:
  • 1,554 Answers
You may have a memory failure.
see this link to access memory slot.
try re-seating it
http://wireball.com/cms/armada_1750_repair#memory_upgrade
Posted on Jan 26, 2008
    Problem Solver:
  • 12 Answers
On the 1750 the setup bios settings are held on the hard drive, if you cant get any further I would suggest the drive is dead.
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
Windows xp was installed on a compac armada 1750 was worling fine but after an hr or so it shut off and now wont boot or run windows all i get is black screen with window xp and 30 sec coutdown and......
On *********** board, there will be a battery, take that out and put it back in. if you have the OS disk. put it in. shut off computer, turn it back on press enter to boot from disk. either re format your hdd by deleting the partioned space or repair.
Apr 11, 2010 | Compaq Armada 1750 Notebook
I got ahold of an old Compaq Armada M300 but it has no operating system. I tried installing Ubuntu and Xubuntu but it says that the bios age 1999 cuts off at 2000. I downloaded the BIOS update from compaq...
Borrow a USB floppy drive, copy the update on a floppy disk. You will need a floppy to update the BIOS of the old computer anyway. Reviving a defunct machine with Linux is a worthile endeavor.
Hope it helps.
Aug 31, 2009 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Accessing bios
Some Compaq's actually have a partition on the hard drive for the BIOS. If someone
> used FDISK to remove the partition, then you won't be able to get into the BIOS
>without either re-creating the partition or by booting from a floppy with the setup
>utility on it. One of Compaq's disks will re-create the partition, but of course,
>will blow away all the data on your hard drive.
>I had to download two programs from Compaq:
>1) PC Diagnotics
>2) Setup for Portables
>I got them from the Drivers section of Compaq's site.
>This was one of the files, it is for an Armada 1750, so it probably won't work if
>you have a different machine, but will give you an idea of what to look for:
> www.compaq.com/support/files/armada/us/download/8093.html
Nov 10, 2008 | Compaq Armada 1750 Notebook
Compaq armada 1500c 400/s/4000/d/m/1
try pressing f8 continually at system startup to enter safe mode. From there you can enter safe mode and reinstall your display adapter driver.. Please rate this answer
Sep 09, 2008 | Compaq Armada 1500C Notebook
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Armada 1700 laptop
remove the battery and power from the A/C and then plug in the battery and a/c cord
Jan 21, 2008 | Compaq Armada 1700 Notebook
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Compaq Armada 1750 Notebook Logo
178 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
