Question about Compaq Armada M700 Notebook
Key board problems
The key board enter in numbers on certain keys instead of letter (p) it enters 6
    Novelist:
  • 113 Answers
I've seen this problem before on several different models of laptop. It is the keyboard (or it's connection) itself going bad. The only option is to either replace the keyboard, which can be expensive, or to connect an external keyboard to use.
Posted on Jan 26, 2008
Pokemon3 kplaur
    Genius:
  • 1,067 Answers
Great i know how that is hit fn key again then should go back FN bottem left see the key that says fn hitt that should go back
Certain letter keys give me numbers instead of the letter on my verbatim wireless keyboard and mouse
Sounds like NUMlock, or another function key like that. Are those numbers on the keys themselves? That's a common problem for laptop keyboards that do not have number pads.
Jan 02, 2014 | Verbatim Keyboard, Mouse, Keyboard and...
Cs6629 how do i enter numbers on to key pad instead of numbers
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
Dec 30, 2013 | Panasonic KX-TG2357 Cordless Phone
How do I change Name of sender?
1. Press: function, 3,#, #
Display shows: your own number
2. Press: start
3. Enter your fax number (max. of 20 digits)
by pressing the number keys.
• To insert a space between digits, press
the # key. To enter "+", press the * key.
• If you make a mistake, press the SPEED
DIAL key to backspace and clear the mistake.
4. Press: start
5. Enter your name by pressing the appropriate
number keys as shown below.
• To enter two letters in succession that
require the same key, press the
SPEAKER key after entering the first letter
• To change case, press the REDIAL key.
Press # or * to scroll through symbols
and special characters.
6.When finished, press: START
STOP
Dec 06, 2012 | Sharp UX 60 Fax
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Laptop key board problems.
Sounds like you have the number lock on. Press the Function key and Number Lock keys together to turn it off.
Feb 27, 2009 | Medion MD-40954 Notebook
Eurovox codes
GOTO MENU PRESS OK ON CHANNEL SETTINGS THEN KEY 1968 TWICE
THEN ENTER YOUR RIGHT KEY TILL YOU GET NAGRAVISION
CHOOSE YOUR PROVIDER PRESS OK
GO DOWN TO YOUR 00 KEY
USE YOUR RIGHT LEFT KEY TO ENTER THE RIGHT ONE
THEN PRESS OK TO GOTO THE NEX ONE
SAVE ON EACH KEY (00 AND 01)
OR
PRESS MENU - THEN PRESS THE YELLOW TEXT BUTTON (BOTTOM RIGHT).
PLEASE TAKE NOTE OF THE BELOW:
TO ENTER LETTER A = PRESS TV
TO ENTER LETTER B = PRESS RADIO
TO ENTER LETTER C = PRESS P-
TO ENTER LETTER D = PRESS P+
TO ENTER LETTER E = PRESS INFO
TO ENTER LETTER F = PRESS RECALL
TO ENTER 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 = PRESS THE NUMBER BUTTONS ON THE REMOTE CONTROL.
ENTER THE PROVIDER & KEYS FOR YOUR AREA & PRESS THE OK BUTTON ( press 4 secs ) TO SAVE. THIS WILL BRING THE CHANNELS BACK TEMPORARILY WHILST A NEW SOFTWARE IS BEING RELEASED.
Hope this is helpful
Jan 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
KEYBOARD PROBLEM
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
Jun 26, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Compaq Armada M700 Notebook Logo
97 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
