Question about Canon PowerShot S50 Digital Camera
The LCD is black when I am taking fotos....otherwise it is working fine
  • abhi_jain26 Jan 26, 2008
    No even after I click the fotos it shows the black fotos only
    Novelist:
  • 113 Answers
Usually you would press the Display button to turn the LCD on, on with options, or off. I leave it off when taking pictures to save on battery life, though it does display each picture for several seconds after it is taken.
Posted on Jan 26, 2008
6ya staff
SOURCE:
Have picture, but no sound
Take the audio directly off the cable/dish box to the speakers and you should be fine.
Mar 02, 2014 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
Nikon coolpix L100 screen just went blank and wont go on again
sounds like a bad sensor...... unfortunately this is a major issue... you are going to most likely have to send it to nikon to fix and it is usually most the cost of a new camera
Dec 02, 2012 | Cameras
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
I was just using my point and shoot S550 when all of a sudden, the photos I am taking produce a blank white screen with some colored vertical lines in parts of the photos. It was working fine a second ago....
I'm having the same problem. The first foto looks alright but the rest is as above. I do'nt have a sollution but i had removed the battery and the memory card and left the camera open in the hope it will be a damp issue. just now i take some new foto's and i still got the stripes but i have a picture. Hope some one will have the right sollution.
Jul 12, 2011 | Nikon Coolpix S550 10 Megapixel Digital...
Lcd is totally black, when taking pics nothing is captured but black
Most cases you looking at repair here.
What it sounds like is you got a bad CCD inside the camera. This would cause black images or no output. now if the fotos that are saved are normal and are not black then the best case would be just a lcd issue.
From what it sounds like you indeed have a issue with the CCD. The repair on that can be pretty expensive, You might want to consider purchasing a new camera at this point if that is the case.
Thanks and we do hope this was helpful.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 06, 2011 | Olympus FE-220 Digital Camera
Dark screen
have you prove to pic fotos. if the camera make fotos,and memorize on the card, but you cant see the foto in the camera schreen this is only a lcd defekt, you must prove if the lcd flat is right connected. if the camera dont pics foto, the problem is in the ccd. you must change the ccd. allor. memorize fotos and you can see trhe foto on your pc...lcd problem contact failure ore lcd faul to change. if the camera dont pics foto...ccd failure to change the ccd.
May 30, 2010 | Canon PowerShot A95 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black screen on a 20ls7d LCD TV
I work at CNN Have had 6 of these monitors go out in as many months. Take out the power supply and change the 2 exploded 680u capacitors. They're being overheated by the underrated MOSFETs on the reverse side of the board. I'm looking for some substitute MOSFETs that handle power better; but replacing the caps will usually fix the problem. Otherwise replace the supply.
Jun 07, 2009 | LG 20LS7DC 20 in. LCD TV
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Apr 24, 2009 | Fuji FinePix S6500 Digital Camera
Video takes time to show
It's a bad ccd chip (Which Samsung is denying). Read some of the horror stories here: http://www.camcorderinfo.com/bbs/showthread.php?t=124288&page=1&pp=15
Jan 20, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Canon PowerShot S50 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
