Question about Maytag Performa PAV2200
Maytag Washer overflowwing
We have a Maytag Performa, I think it is about 8 years old, series PAV2300 top loading washer that just last night kept running. It would fill all the way up and continue to run water non stop till we manually shut it off, and then would not drain. water was pouring out of the bottom of the washer. I've checked all the hoses for clogs, loose connections, found nothing. ANy thoughts?
  • emailabro Jan 30, 2008
    Thanks for the advice, I did check that hose, it too was disconnected so I put it back on, and the thing STILL over flowed! After doing some more research online, I determined that more then likely my Water Level Switch went bad. Ordered the part online, through this website, ran about $70 after tax and shipping costs. Real easy to replace behind the control panel, less then 5 minutes and the washer was working good as new! Problem Solved!
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Posted on Jan 28, 2008
6ya staff
SOURCE:
My Maytag PAV2300 Top Load Washer is nine years old. It just started making this LOUD grinding noise when it's washing, rinsing and spinning. What could it be?
I have the same type washer and it is about the same age makes the same grinding noise as the above mentioned one. Did this person ever find a solution?
Aug 31, 2010 | Maytag PAV2300 Top Load Washer
Stagnant old soap smell. maytag performa 2003 model
the inner drum needs to be taken out and the outer drum develops a thick gunk of softener and detergents. have to have a spanner nut tool to do it. they actually sell one that works for all washers. it has different inserts for different brands.
Aug 01, 2010 | Maytag PAV2300 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
'need wiring diagram for door latch on maytag performa model#pav2300. I have the part. Retired industrial electrician.
Not sure if this will paste here if not enter your model # at www.appliancehelponline.com the diagrams will come up on the right hand side.
May 03, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer top load
hi thanks for the question i think you could have a problem with your tub bearing or you could have a piece of clothing caught between the tank and tub remove the front lift up the top remove the plastic top and look you will see if you have something caught in the space between those two pieces thanks the appliance doc
Sep 24, 2008 | Maytag PAV2300 Top Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
215 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
