Question about Refrigerators
Locate evaporator condensate drain tube
I have a ge top freezer refirigerator model tbx18jatjrwh, water accumulating under veggie bin, want to try and unclog the tube
thanks
  • 1 more comment
  • dr smith Jan 26, 2008
    the door seals are ok ,
  • robert samples May 11, 2010
    check your door seals to make sure they are sealing first the drain tube is in the freezer behind the evaporator cover
  • Anonymous Mar 29, 2014
    I'm trying to gain access to the freezer evaporator drain to unclog it.
    President:
  • 1,314 Answers
Next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Posted on Jan 26, 2008
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water collects under the produce bins at the bottom and leaks out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Oct 11, 2009 | Refrigerators
I have a GE Profile TBX19PAYBRWW, there is water dripping on the inside of the refrigerator and collecting under the vegetable bins and then eventually runs out the front of the door. What can I do to fix...
OK, there is a dranage tube located somewhere at the back or so, and it is probably cloged or piched. Remove your contents of the fridge as necessary, located the tube, check it out, and clean/unpinch as required. That should get things flowing again.
Oct 05, 2009 | GE Profile 19.0 cu. ft. Top Freezer...
Model TBX21KLK water pooling UNDER vegetable bins
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
GE frdge model ctx21eazhrww has water accumulating under lower crisper drawers and spilling onto floor
Aug 20, 2009 | Refrigerators
Magic Chef CTB1722 refrigerator leaking water from inside fridge. The water pools under the fruit and veggie bins and leaks onto the floor.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 12, 2009 | Refrigerators
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
771 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
