Question about Mitsubishi VS-55707 TV
Mitsubishi VS-55707 Shuts Down
Picture is great but occasionally TV will get a few horizontal lines across the screen then shut down. It will start right back up and work perfectly for 2 hours, 2 days, 2 weeks before shutting down again. Diag code is 2-4
What might be the cause and how do I order the parts (I have the service manual with Mits part numbers but can't find anywhere to order them)?
  • 105 Answers
I would not recommend working on a TV unless you have a great deal of knowledge about them.
it is probably your power relays do you have a part # i could help you look around
Posted on Jan 26, 2008
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Will not turn on. Shuts off immediately after turning on.
Sounds like the vetical deflection went out. Most likely have a leaking picture tube and the cooling fluid has goton on the board so you would be beter to replace if that is it.
Sep 03, 2009 | Mitsubishi VS-55707 TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Jumping screen on a mitsubishi vs-55707
check the high voltage leads on the multiplier flyback transformer for leakage
Nov 17, 2008 | Mitsubishi VS-55707 TV
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
Poor
Hi there!
Sounds like convergence Amp to me. Refer to a repairer if you are not sure. Good luck,JUS004
Jan 11, 2008 | Mitsubishi VS-55707 TV
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Set will not stay on
Better get this checked out by a technican. One possible reason could be coolant from the picture tubes leaking down onto the printed circuit board causing this symptom which could end up destroying the circuit traces on that board. Other possibilities include problems in the power supply or deflection circuits. If the set is over 8 years old, I would just replace it with a HDTV.
Jan 30, 2007 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 TV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
