Kitchen Ranges
Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
Front panel off
By carrosales on Jan 26, 2008
Helllo, the front lcd panel is not working due to a heating episode when doing a self oven cleaning the unit overheated and the break was triped. After power back on only the burners work and not he LCD panel that controls the oven and the microwave. Any suggestions would be appreciated CR
Comments:
Jan 26, 2008
- Yes the brand is Sharp and the model number is KB-3300J
Feb 14, 2008
- Hello can you tell me where to find the oven temperature fuse. This is the only thing we haven't being able to test to solve the problem.
Feb 14, 2008
- It is a rangemicrowawave combination. Thanks Carlos
Feb 21, 2008
- The problem with the LCD panel still continue. We change some parts but still not going. We will try to put it in the curve, that will take care of the problem for good. Thanks for the help any way.
Mar 09, 2008
- We found the problem. however the fuse TCF is located in between the microwave oven and the regular oven. It is in place where can't be reached. The solution was to bypass it ant it is working just fine. Until I can get a new one. Thanks  Carlos
Clarification Request
Posted by tech17 on Jan 26, 2008
brand and model would help
Same Problem
Oct 26, 2008
-   LAST YEAR I HAD A PROBLEM WITH ELECTRICITY IN HOUSE . STRIGHT 240 WENT TO THE OVEN AND LKE ALL OTHER PRODUCTS IN THE HOUSE THE LCD WAS KNOCKED OUT. OVEN DOES NOT WORK NOR MICROWAVE. COULD IT BE THIS ROUND SHAPE FUSE?-   Lopezt215
Feb 14, 2008
-   Do  you know where the oven temp fuse is? I have a technician working on the unit but we wan't find the fuse and after doing some testing that is the only connection we can't test. Thank you Carlos-   Guest
Best Solution
posted on Jan 26, 2008
Helpful)
tech17
Rank: Guru
Rating: 88%, 1540 votes
a lot of theese ranges have whats called a thermal fuse or tco that will open when the oven goes into an over heat condition i don't have access to sharps data but if you call you local appliance parts store they can look it up for you and tell you where it is youll have to buy a new one any way
Comments:
Feb 14, 2008
- this came in as a range is it a rangemicrowave combination or an over the range mircrowave
Feb 14, 2008
- ok pull the range out most of the time you take off the back panel ant the fuse is there it doesn't look like any fuse you've ever seen its a round disc standing on two little legs with two wires on it on some its called a thermal fuse on others its called a tco or thermal cut out most of the time you can follow the wires from the heater elements and find it i havent had hands on with sharp but they are all pretty much the same
Was this helpful?
Yes
No
Solution #2
posted on Mar 09, 2008
Not Rated)
angieski2
Rank: Apprentice
Rating: 0%, 0 votes
I have a es200/300 smooth top frigidare, the bave will not heat up, every other botton works fine, help please
Was this helpful?
Yes
No
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
which brand Dual fuel slide in range is the best?
Answer
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,... (More)
Answer
my control panel went out. no clock or anything displayed. lights dont work either. stove top works.
Answer
i got a leak under the injection pump on my 1998 mercedes benz e300 diesel
Answer
Will not heat correctly. You set the temp required. And it apears to start a preheat cycle. But an... (More)
Describe your Kitchen Ranges problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Range Experts
Top Range & Oven Repairmen
in , CA
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
