Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Heater want work right
Kicks on goes to med kicks off and flashes ee2
EE2 Means only one thing. The flame rod is not detecting a flame.
The cause could be anything that prevents a flame.
1) no fuel
a) out of fuel - check tank
b) clogged line - clean
c) clogged filter (either on tank or screen in stove) -clean
d) igniter not working- replace
e) dirty flame rod (clean, then determine why it's dirty or it will happen again)
those are the quick fixes other than that contact the dealer you bought it from.
Posted on Jan 26, 2008
My heater keeps saying ee2 i know it has fuel , i have checked the screen , what do i do next ? please and thank u
ee2 are these possibilities.
Out of fuel
Fuel tank valve closed
Air pocket in fuel line
Clogged flue pipe
Clogged fuel strainer I
gniter, circuit board,
flame sensor
or fuel pump malfunction
Blower motor malfunction
https://www.toyotomiusa.com/OwnersManuals/Vented%20Heaters/Name%20begins%20with%20Laser/Laser%2056%20(Type%20I).pdf
Apr 10, 2016 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
Jan 05, 2013 | Rinnai Toyostove Direct Vent Heater:...
Empire earth 2 is not running in my win 8 .I have no external grapics card.
Until someone (hopefully Microsoft) comes up with a patch, you will have to run the game with a batch file. Open Notepad and paste the following text:
taskkill /F /IM explorer.exe
EE2.exe
Start explorer.exe
Now Save As [All Files] EE2.batinto your EE2 directory that contains EE2.exe. Right-drag that batch file onto your desktop and create a shortcut. You can right click on the shortcut and choose Properties to change the icon to the one in the EE2 directory (EE2.ico). You can do the same for the expansion (EE2x.exe) if you have it.
You may still need to run the program as an administrator and in compatibility mode, and possibly might need to Take Ownership of the EE2 folder.
Jun 23, 2012 | Sierra Online, Inc. Empire Earth II / 2...
I have an error code of EE2. The system will not
First- do you have enough fuel.
Does the unit ignite or not
More info would help me
Total Toyo
(907) 488-9179
Dec 15, 2009 | Rinnai Toyostove Direct Vent Heater:...
Gettin an EE2 error - replaced the fule filter at the tank, removed and cleaned the sump screen, no luck. Does the sump screen on this stove fit into the sump with the open aspect of the screen facing the...
The open end goes toward the back of the heater.
Next try cleaning the flue.
Other potential causes for an EE2 are malfunctions of the circuit board, flame sensor or or fuel pump.
-Helping Hands Services
Fairbanks, Alaska
Oct 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
Laser 56 code E22 after slight banging noise upon trying to ignit
You have a fuel problem. The ticking sound is the pump starving for fuel. It's either low fuel, no fuel or dirty filters. It's an easy fix.
Tom Hawkins
Bethel, Alaska
May 14, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo Laser 73, starts, fires then goes out, flashes EE02
here is the problems associated with code EE02.
problem cause solution
no ignition: out of fuel check fuel gauge or tank, refuel
fuel tank valve closed open valve turning clockwise
air pocket in fuel line push reset button on the fuel sump, located right inside .
once
clogged flue pipe clean flue pipe
clogged fuel strainer clean fuel strainer
ignitor,circuit board, consult dealer
flame sensor, or fuel
pump malfunction.
it sounds like it may be a clogged strainer located in fuel sump or a bad circuit board hope this helps
Jan 22, 2009 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
255 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
