Question about Mitsubishi WD-52628 52" Projection HDTV
WD-52628 lamp replacement
I got a lamp and cartridge from laptopsforless, and it didn't fit. So I took the bulb out of the cartridge and put it in the original cartridge and it worked. My problem is that my whole screen is pitched, slanted, skewed clockwise, or the right side is lower than the left.
Any ideas?
  • dlpnotforme Jan 26, 2008
    Thanks Coldcut. I did just as you say prior to posting this. It is completely seated and I have the same result. There are differences in the bulb itself. One is that the edges of the new bulb glass are open. Meaning if this bulb blows, glass will easily fall out. My old lamp did blow and glass was all over, but contained within the bulb. The other difference is the dimension of the new bulb is probably 1 mm wider and possibly the depth is longer, but not by much. It sounds like I need to try and get a better matching bulb.
  • Shemans Apr 24, 2009
    I have an issue with a flashing yellow light after changing bulb. Is this due to the bulb not being seated correctly in cartridge or the cartrige not seated correctly in the tv?
    Genius:
  • 1,554 Answers
The reflector on the new bulb must be the same length/height.
or your beam will be off center normally causing gray areas.
Most likely you did not seat the tray/carrier correctly
be certain the lamp is seated fully.
never touch the lamp with fingers as the oil will make hot spots.
pull out re-seat the tray again.
Posted on Jan 26, 2008
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Can i just replace the lamp on my mitsubitshi wd-60735 or do i have to replace it with the cartridge also
Original lamp comes in cartridge, longer lasting and easy to replace
Bulb that replaced in old lamp cartridge is low cast thing and does not work longer.
Choice is yours.
Aug 20, 2010 | Mitsubishi WD-60735 Projection Television
Wd-52628 bad lamp or bad ballast?
you cant - unless you have another tv to test it in. May be a ballast or the cooling fan for the lamp is not working.
Feb 02, 2010 | Televison & Video
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
To replace the lamp, do I need a whole new
No,shouldn't tries,not done correctly well also damage,power board parts.
Oct 03, 2009 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
