Question about Maytag MED9600S Electric Dryer
Maytag Epic Front Load Dryer
I have just set up and can't get the dryer to start. When you follow the start up sequence and go to push start, the system beeps twice and the timer flashes? No go??????????
  • mrszanca Feb 05, 2008
    Same problem here, the door is shut, the lint is empty. I hit start, it starts beeping and wont turn on. No circuit issue. and is plugged in
  • Gary Davd
    Gary Davd May 11, 2010
    is the door closed??
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Posted on May 12, 2008
We just put the dryer in, and when we turn it on, there is a loud scraping noise.
Posted on Apr 24, 2008
How do I remove the light wiring harness from the front panel?
Type Maytag Epic Z into YouTube and see if the video comes up, thanks!
Jun 25, 2015 | Maytag Epic z Front Load Gas Dryer
What does error f 1 mean?
Type Maytag Epic Z error into YouTube and see if the video comes up, thanks
Jun 21, 2015 | Maytag Epic z Front Load Electric Dryer
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
Maytag epic front load electric dryer is turning but only blowing cold air ?
Unplug dryer. Remove heater element, and inspect element for damage. Use an ohm meter to check for continuity. Should have some resistance. Should not be open or short.
Oct 18, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
Epic z dryer door will not lock
Unlike ovens and refridgerators, the gasket on a dryer will sometimes swell with usage. I would highly reccomend that when you close the door push on the glass right beside the latch with some force until you hear a click. It should be okay. This is a very common problem on commercial and consumer machines.
Jul 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Maytag MED9600S Electric Dryer Logo
406 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
