Question about Toshiba 36AF42 36" TV
Dead IR reciever
Now, I can get the part for $10. I just don't want to take the tv to pieces and screw something else up. Does anyone have a service manual? I'm handy enough with computers or regular board repairs. Just need documentation to make me feel better about it. Thanks in advance...
Doc
  • fixyaismybff Mar 12, 2009
    Hey Doc,
    Where did you get the replacement IR receiver for the 36AF42 Toshiba tv?
    What is the part number?
    thanks
  • 4 Answers
You don't need manuals to repair this beast.
Note all your cabling as the back plugs are many.
Remove the 8 screws in back.
Remove 4 screws using an angled phillips or angled phillips rachet that holds the left front module board in.
Carefully lift out the inter module connecting plugs. These are delicate so pry on one side with a small screwdriver then the other until it is free.
Lift out the blue LED from its holder as it is reused. Desolder the receiver. There is 5 points. Solder new part in. Reverse steps.
Posted on Apr 02, 2008
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
Kdl-32l504
TV Parts Universal TV Stands DLP Chips ShopJimmy They should have the IR board for your Sony TV.
Sep 03, 2017 | Televison & Video
Where is dish network DVR VIP622 IR sensor location
Hello, Daniel Busa with Dish Network's customer service department. The ir sensor would be right below the blue green and orange light on the reciever.
Oct 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Remote to TV 1 doesn't work - buttons light up, nothing happens
Press the number zero for 10 seconds and wait until the "remote wizard" pops up. Then just follow the instructions on how to program your remote to your receiver box.
Oct 20, 2009 | DISH Network IR Remote Control
IR reciever in my Magnavox 15MF400T/37 does not respond to the remote.
You basically have to take the tv apart backward to get to the front. Start with the back panel unscrew all the screws. Then you will see the internals. IR sensor should be botton left side if you looking down on it.
Sep 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
TV Remote control
The IR reciever should be in the front of the set where the remote IR window is located.
I can tell you that there is a lot more that can go wrong than just the IR reciever. There may be a buffer amp along the way to the uPC, or there may be a fault with the uPC itself. The fault may also be a cold solder connection, or a missing supply voltage to the the IR reciever or to some of the components involved in the IR signal process.
In opening and working on your set, there are serious safety issues involved. You should be giving the set out to a trained and experienced TV tech for proper and reliable service.
Jerry G.
May 05, 2008 | RCA 32V420T 32" TV
REMOTE DOES NOT WORK ON SYLVANIA TV
It sounds more like a problem with the TV, than the remotes. It's possible that the IR reciever or microprocessor for it have pooped out. It's something that would have to be serviced by a shop, but due to the age and size it would likely be cheaper to replace the whole TV.
Dec 04, 2007 | RCA F25432 25" TV
I just can't get it to work, new batteries and all.
First check if the remote control is sending an infrared signal. If the LED is flashing, this does not mean the Remote control is sending the IR signal. There is a separet Infrared LEd that sends the signal. To check the IR, point the remote control in a video camera or any camera with real-time monitor (phone cam, webcam, etc.) and press any button. You will see a white flash coming from the Remote control. thjis works best if the camera is black&white, for color camera, the IR is still visible but quite faint. Another way of checking the IR (if you do not have a camera) is to press the RM in front of another device with remote control and while doing so, press the correct remote control . If that other does not function or functions erratically, then the remote control in question is emitting an IR signal. If there is no IR coming out, the solder conection of the IR LED might be the problem. It is rare that the IR LED will be damage because the remote control is only 3 volts. If the remote control does emit an IR signal, then the TV remote reciever is defective. I had this problem with a CD player that I have fixed. The IR reciever looks like an LED (dark colored) with three pins (V+, signal, ground). Cost less than $3
May 18, 2007 | Jensen JER-323 Remote Control
Toshiba 36AF42 36" TV Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
