Question about LG Art Cool LA121CNP wall/window Air Conditioner
I have a promblem
First i want to say that my english is not very good.My air-conditioners is LG LS-N096JLA0.When i strat my clima,after 2-3 min. outside start compressor and after 2 min. stopped and inside the small green lamp starts to flash.We open the outside and took the board off.There was one burned transistor GT50J102 there,who i change.
When i start the clima again,everything was repeating.Now i take off the board again and tehere have 3 burned capacitors C02Z,C04Z,C06Z and same transistor GT50J102.Do you know wheres the problem ????
Thanks.
My email is the.beast.bg@gmail.com
Wa sir loho o chri wahed akher
Posted on Oct 07, 2008
    Scholar:
  • 72 Answers
Replace the whole board.
Posted on Jan 27, 2008
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Alaways heat i want toreset the remote
TRY SHUTTING THE BREAKER OFF, FOR ABOUT 10 MIN . THERE SHOULD BE A LITTLE HOLE IN YOUR REMOTE , USE A PAPER CLIP TO PUSH IT (LIGHTLY !)THAT WILL RESET THE REMOTE.. GOOD LUCK AN VOTE IF I WAS OF HELP.. YOU KNOW I DO THIS 4 FREE RIGHT ?
Sep 10, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG Split Air conditioner is not giving cool air
you will need to check to see if the compressor is coming on, make sure it is getting the 220 volts, the wires are connected and not burnt, and that the fan is working. Check these things and if they are all good then feel free to past again, Tim
Mar 13, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Lg spilt system turns of after 5 mins green light flashes
You need to note the pattern of the flashes, short or long flashes etc.
there is a legend that explains all the possible codes.
Example: 3 long flashes 1 short flash, the legend will say something like hi pressure safety switch
or low pressure safety switch , this could mean dirty coils, inside and outdoors, or bad fan motors either location as well, the compressor may be over heating or overloading, or be gong bad. a capacitor may be the culprit, what you can do is see the fuses and airflows good and no coils blocked etc , notice if any motors stop causing the flasing lockout condition.
Dec 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lmv240he & lav181cnw
I searched the website but could not locate the literature for that particular unit. I recommend you contact the manufacturer's technical support department. They should be able to email you the manual and direct you how to obtain replacement remote controllers.
Technical Support
For technical support on a DFS, PTAC or TTW Product call 888.865.3026, then press 2.
I hope you find this helpful with your endeavor. Good Luck! :-)
Mar 08, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Split clima compressor
check the compressor itself,
ohm out the two windings and ground
you should read continuty between the poles
and open to ground
id be willing to bet your start windings is open or has a direct short to ground
Oct 20, 2009 | LG Art Cool LA181CNW Split System Air...
How many pressure for recarge the clima of lincoln
Good luck, R-134a is incompatible with an R-12 system.
Aug 11, 2009 | Heating & Cooling
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
99 people viewed this question
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
