Question about Microsoft Xbox 360 Console
We cant see the video only the sound is perfect
My problem is when we on the xbox 360 the sound is perfect but the image is black, or with some points
  • 25 Answers
Are you using a hd television?
-if so, then replug in your plugs into the television, and make sure that the av cable to the xbox360 console end, is switched to hd.
-if not, then recheck your plugs, check that the av cables to the xbox360 console is switched to tv.
and if this still does not all work, then, its mainly where you plugged in the video cables into the television. so my main advance to you is to recheck where you plugged the video cables.
Posted on Jan 26, 2008
6ya staff
SOURCE:
Image being Captured/Recorded is in Gray Scale (Black and White
Not knowing what capture card you have, I can only guess that you are using the componet video input to the capture card and the composite video out of the Xbox. If you are using HDMI, it could be a bad HDMI cable. This link:
https://support.xbox.com/en-US/xbox-360/console/connect-xbox-360-console-tv
might be helpful in figuring out your issue.
Nov 04, 2017 | Pinnacle Computers & Internet
I have black ops and i cant even get through the first part with a video that says classified and all that stuff, and then after that either it says a error message that says bad syntax bad token see...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
When the xbox is switched on a black fuzzy screen appears, we have tried different wires that work with other xboxes and it still does not work. We have also used our wires on other peoples xboxes which...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Feb 23, 2010 | Microsoft Xbox 360 Console
I have a modded Xbox 360 it has no video only sound
first we need to know what type of mod... a hard chip or a softmod?
Oct 09, 2009 | Microsoft Xbox 360 Console
Image blacks out !!
u have a softwere problem with your 360 right to microsoft and tell them about it and they will get u to send it bk to them so they can update the softwere of your xbox 360
Aug 03, 2009 | Microsoft Xbox 360 Console
Perfect sound but no video, tried on 2 TV's. No red lights.
try changing the sound settings in xbox menu make sure they are set to the type of input you are using
Jun 04, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360 NTSC only Black and White
yes xbox 360 NTSC only in black and whit colours
Feb 06, 2009 | Ulead Videostudio 8 for PC
My Xbox 360 keeps showing a black screen
1. Get 3 towels then switch your Xbox 360 on.
2. Wrap the Xbox 360 in the towels [Note - You must cover the WHOLE Xbox otherwise it won't work].
3. Leave your xbox for 25 mins in the towels.
4. When the 25 mins is over take off the towels of and let your Xbox 360 to cool for 20 minutes, enjoy fixed gaming for the next 4-7 days. Once you get a blank screen repeat this process.
[Why Overheat it?]
When overheating it you attempt to solder the dis-connected wires back to the motherboard.
I recommend getting it fixed instead.
[What does it Fix?]
This fixed the Red Ring of Death, and the Blank Screen of Death
[DANGER]
I do not take responsibility for this. This is mainly for those without warranty or money to repair.
The premise is to wrap the towel around the 360 and to let it heat up. This will weaken solder points and hopefully re-join broken connections. The problem with this method is that you have no control over what solder points are weakened and there is no way to prevent further damages caused by the heat. It is better to send a 360 in for repair with the three year warranty that MS put on the 360s, because if you try the towel method and then send it in for repairs, they will know by the solder points being misshapen and it will void your warranty forcing you to pay for the repairs.
Oct 19, 2008 | Microsoft Xbox 360 Console
COLOUR
If this has happened to your console it means theres ether something wrong with your AV lead
Or CONSOLE
before even considering to ring Microsoft borrow a friends wire.
if it still changes colour Call microsoft .
Probably to do with the av connectors inside the xbox
theyll fix it for free if your console is still within the warranty
pls rate.
Sep 01, 2008 | Microsoft Xbox 360 Console
Xbox 360 with sound but no image
Make sure your av wires are properly connected, it may be faulty video wiring, if not than your 360 is more than likely defected.
Jun 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
