Short circuit Help! my machine trips the fuse when operated, seemingly only on programme '3'. I have disconnected drive motor and water pump, it still trips. No sign of a leak. There are 2 sensors, along with a ground connection at the rear base of the drum, with the left one disconnected (black wire) it runs ok. What does this sensor do? could it be u/s? or could it be the circuit board at the other end of this black wire (visually ok) mis behaving? The sensor doesn't look easily replaceable. Any advice greatly appreciated...
  • andi123 Jan 29, 2008
    Just fixed it. dodgy heater element!
  • 770 Answers
Please post complete model # from the unit need to know what we are working with........
Posted on Jan 26, 2008
  • Gary Davd
    Gary Davd Jan 29, 2008
    GREAT if you need help on any other Appliances Just let me know
6ya staff
SOURCE:
My hoover optima washing machine is tripping my electricity supply. Have tried disconnecting heating element and looking for damaged wires.
Ian if the circuit breaker is a rcd it will trip off the supply if it
normally detects a very small leakage or unbalance of around 35 m /amps this could be a small water leak onto live parts in the machine or a minute short to earth on one component ,make sure all parts are dry / is it tripping when you switch power on to machine or does it trip when machine is in cycle mode.
1. its as first suggestion 2. it's a component like pump or drive motor that;s causing problem. hope this is of some help,g.luck
Nov 11, 2016 | Hoover Washing Machines
Hotpoint Aquarius Dryer TL61
the power supply is not able to generare the particular temprature to heat the heating element as required.and so the pressure that gets exerted to genrate an extra heat blows down the fuse.
Aug 12, 2008 | Dryers
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
When turned on you can hear a buzzzing, like electrcicity going into the pmp then pump heats up and trips its saftefy switch. Motor does not turn.
I am assuming that this is not a brand new installation. If it is, go to http://www.femyers.com and download a manual for your pump.
If the pump has worked properly in the past, what seems to be happening is that the motor is locked up and the built in thermal protection is correctly protecting the motor. Or if by "safety switch" you mean the circuit breaker is tripping, then the following still applies.
The pump impeller may be jammed with debris, or the motor bearings may be worn out, causing the rotor to jam and stop rotating. Also a possibility - the seal between the pump and the electric motor has failed, allowing water into the motor and causing a short circuit which trips the breaker.
It is probably time to call the repairman, or replace the pump. Don't keep trying to turn on the motor; it will not fix itself and you may make things worse.
Remember, these pumps must be primed with water first before first use. Look in the Operating Instructions manual.
Mar 24, 2013 | Myers Pump QP10-3
I have just bought a euroline 40 glass washer but it keeps tripping all my fuses when I turn it on I have tried different circuits but still trips
Possible there is short within the power board and so it uses more current than designed. You can remove the panel and check for short within the panel board. Check for visible damage to the board. It can be shorted surge capacitors, protectors or rectifiers. If not there can be damage within Also disconnect the motor drive , isolating the circuit and if the power does not trip you can check this circuit.
Jan 17, 2013 | Washing Machines
Whirpool ADG 7550.......my dishwasher starts and seems to run fine, but after a minute or so it will stop, shortcut and drip the fuse. thereafter it fuses every time I switch it on. can you pls give some...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .rinse and then finally the drain valve/pump activated so as to drain off all the water.
Now since the washer trips after the start then it is possible that there is a short in the controller, the motor or motor drive or the heater. You need to disconnect the lines to the motor and heater to confirm if the washer starts back or the circuit does not trip futher.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below for tips to open:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 18, 2011 | Dishwashers
My washing machine is constantly tripping the electrics, it is about 4years old & was working fine yesterday.
Possible that there is a high drain on the circuit and so makes it trip when the circuit shorts. This needs a check with a elimination of the circuits. You will need to fist check the main motor and the capacitor for any excessive drain. check if there is any mechanical jamming of the drive which can result in the trip as the motor is powered.
Also it is important to check the main control circuit, check the input valve and the drain pump/valve. Disconnect one by one to confirm.
Mar 29, 2011 | Indesit Washing Machines
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
