I HAVE A Pocket size 160GB HDD Player with hard drive how do i store vidos file on it so i can view it on a TV Paul
  • Anonymous May 11, 2010
    Please list what type of Hdd player you have.
    Champion:
  • 238 Answers
In ordr to watch the video files, first u will need to format the USB HDD to fat32, then connect it first to the usb port of the PC and transfer all the video files whichever format to the drive, then connect it to ur TV via the EP Pin AV out.. let me know
Posted on Jan 28, 2008
  • 39 Answers
You connect your hdd pc usb port
Posted on Jan 27, 2008
6ya staff
SOURCE:
I have managed to copy my video files onto my Buffalo HD-PCTU2 Portable Hard drive however when I try to view the files now my computer is telling me that windows cannot open the file as it needs to know...
Right click on one of the video files, choose Open With. A window will pop up, highlight the video player that you want to use for your videos, and check Always Use This Program to Open This Type of File. You are done. Good luck.
Jan 03, 2018 | Buffalo Technology 320GB MINISTATION TURBO...
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
I used my Lacie 160GB Mobile Disk from morning to evening on my Dell Latitude D610 Laptop, until evening when my younger brother came home from work, he demands to copy some movies from my Lacie 160GB...
This happened because your brother's computer is infected with a virus or otherwise corrupted. Take the drive and both computers to a local tech to further diagnose the problem and that tech can probably recover your files. I think your brother should pay for the repairs - his computer has some malware that may have overwritten your files. This is why you should do two things - first, always have two kinds of backups - copy vital files to a usb memory stick, and second, don't lend anyone any device you plug into your computer - that is how viruses are spread.
Apr 06, 2017 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
How can I change the original HDD with one bigger
If you clone the 160G drive you will always end up with a 160GB drive. COPY {instead of IMAGE or CLONE} the 160GB contents to the 500GB drive and you'll have lots more room on the 500GB drive.
Sep 28, 2009 | Philips DVDR520H DVD Player/HDD
Accidentally dropped my pocket hdd hitachi 160GB and now it doesent works. It only makes a scratchy noise. Please help me out with this.
you have lost your fat file and, have possibly scratched the disks the scratching sound you hear is the heads searching for the fat file. if you have important files on the drive send it to a recovery service if not you may be able to refomat the hard drive and, use it again
May 22, 2009 | Hitachi 160GB 5400RPM 9.5MM 2.5 ATA-133...
I was given an IBM laptop t41 without a hard drive.
it will support any standard ide hard drive
Mar 18, 2009 | Computers & Internet
Low capacity problem
Mostly this is affected by match used to construct the drive geometry. The narrative below is courtesy Tiger Direct of Canada and is their copyrighted content.
When we ask our customers if an Answer is satisfactory, the requested rating is four diamonds for a thorough answer. Hopefully, you will find the below content achieves that mark.
  1. The way size is calculated and displayed.
  2. Any "Partitions" on the disk will change the total in a specific partition.
  3. Hidden files and folders decrease available space.
  4. Compression increases the apparent size, but not the physical size.
  5. Drives larger than the OS or Drivers natively supports.
hddsizescreen.jpgFirst, the definition of a megabytes (or gigabytes) is a unit of data storage capacity measured in 1,048,576 bytes (or 1024KB). The larger the numbers, the more apparent the size difference will be when listing the size as megabytes (or gigabytes) versus bytes. Actually, both numbers are correct. The noticeable difference is due to the 1024KB definition of a megabyte. This is why a 95.3GB hard drive can also be listed as having 102 billion bytes of total space. Just think of it as "round off" In the screen shot at right: The first number is the total number of bytes, the second number is based on the number of megabytes or gigabytes.
Second, some computers have a non-DOS hard drive partition that is used for features such as Save to Disk, Hibernation, or Recovery. This partition is not normally reported by the operating system, although it can be viewed using a disk partition utility. This is very common on desktops and laptops. NOTE: Partition information will be created or formatted automatically during initial system setup and a system recovery.
Third, by default, all system files are hidden and cannot be seen. This may adversely affect the reporting of available hard drive space. You can set your Folder Options so you view system and hidden files and folders, but do be careful as changes to system files can adversely affect your system.
Fourth, if you turn on Compression for a drive, it will increase reported free space and used space, but since compression is based upon the actual contents, this number is not fixed, but will change as files are added or changed.
Fifth, older operating systems did not support some of today's larger drives, so the total space reported may be much smaller than the drive specifications.
It is also worth noting that bad sectors are corrected by your operating system and can change the total drive space, free space, or used space as well.
So as long as a drive is reporting a value approximately close to the specification value, you can be comfortable that you received the right drive and that you are getting to correct data storage. Of course, tuning of your drive's partitions and options can yield optimal values, but this is not something for the average user to explore.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
54 people viewed this question
Ekse
Marvin
Marvin
